@HeatitControlsAB Any news on the availability of a production Trm-6 - driver?
Same here. I’m using the beta driver for the ztrm6. I’m happy with the thermostat (apart from the fact that the “load” setting doesn’t work) but why isnt there a smart things driver for this yet? The supported thermostats aren’t available to purchase anymore.
doing some fixes and will try releasing it this week.
Which Load setting do you mean? You mean the Size of Load parameter? This will be fixed, uses incorrect parameter size value when chaning the parameter.
Fixed now, my apologies for the inconvenience.
In the driver it is called “Size of load”, and I assumed this could be used so the thermometer can calculate meter values when there is no actual load (ie when set up with association group 2). Setting this to something makes no difference to the meter output.
Yepp, that is correct.
This will be fixed in next version, it can be set from the menu on the device locally in the mean time.
TRM6 and TRM6 DC added to release channel
Thanks, chuffed!
@HeatitControlsAB
The released production driver does not work properly for the Trm-6
- in Sensor Mode= PWER Regulator-mode with Regulation Mode=PWM Regulation.
Whereas in this mode of operation the Power level for Regulator can be set on the device itself, it cannot be set using the app. And a Power level for Regulator setting set on the device itself is not transferred to the app settings for the device.
This means that remote operation is impossible.
- Also, if the device is Off it cannot be set to any other state (COOL, Heat,..) using the app
This means that remote operation is impossible - no matter the setting of the Sensor Mode
- In addition, access to any of these parameters are not available in Scenes/Routines.
This means that automations cannot be created.
(Z-Wave repairs or removing/restoring power doesn’t help, neither does clearing the app cache)
Hi,
I’m new here, so I hope I’m in the right place to get some help on new Edge drivers for the Heatit Z-TRM7.
I just bought 3 of these thermostats, but the get recognized as Z-Wave Switch and not a Thermostat.
I think the Manufacturer code is not mentioned in the Edge Driver version HeatIt Z-Wave Thermostat 1.5
I installed it and it’s available on my hub. But I can’t link it to the Z-TRM7 device.
Any help would be greatly appreciated.
Regards,
D
