This sensor wonβt work with @Mariano_Colmenarejo driver since it using cluster EF00 with Data Points (DP). You better use @w35l3y driver personal-tuya-devices. Here are the Data Points involved:
I just found this on AliExpress:
US $19.64 | Tuya Smart Zigbee light and rain sensor 2-in-1 function, built-in lithium battery , Light and rainwater detection Smart life App https://a.aliexpress.com/_okTx7Ll
Could you please add to _TZ3000_tgddllx4 power reading interval setting option you did for other devices? It is missing and this switch does not report actual power other than on request interval. it uploads device profile βswitch-power-energy-plugβ vs requested βswitch-power-energy-plug-refreshβ. Many thanks.
This device was added almost 2 years ago and I am not aware of this device having the periodic power and energy reporting issue. It seemed to be only linked to some manufacturers of the TS011F model and your device model is TS0001
Did you pair it directly with this driver or did you change the driver from a different driver?
The device has to be paired directly with the driver for the periodic reports to be configured correctly.
Please try removing it with the app and pair it again with the search nearby option to see if it is configured correctly.
Hi @Mariano_Colmenarejo, thanks you very much but still the same. I tried to remove it and pair again directly with βZigbee switch power Mcβ driver. It does not show actual power level after switching on, only when reloading ST screen it show 3,2KW (heater). What is funny is when switching off, it went down correctly to 0KW after 2 seconds. I guess the whole point is that it does NOT upload βswitch-power-energy-plug-refreshβ profile for me to set power reading interval as I can on other plugs, using the same βZigbee switch power Mcβ driver. I see it uploads βswitch-power-energy-plugβ with NO βpower and energy reading intervalβ in driver setting as an option. See the screens attached. Also when I look into your fingerprint for edge devices, - id: β_TZ3000_tgddllx4/TS0001β
deviceLabel: TS0001 Plug
manufacturer: _TZ3000_tgddllx4
model: TS0001
is set as βswitch-power-energy-plugβ and not as a βswitch-power-energy-plug-refreshβ. Many thanks. L.
changed to βswitch-power-energy-plug-refreshβ profile in this driver version.
You need reinstall device to assign the new profile
This profile was only created for devices that are not configured correctly. If you have already tried reinstalling it and it is still the same, I will change the profile.
If you could send the CLI pairing logs, we could see what the device answers when trying to configure it.
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Switch Power Mc
Version 2025-01-18T15:59:40.637242518
- id: "_TZ3000_tgddllx4/TS0001"
model: TS0001
deviceProfileName: switch-power-energy-plug-refresh # modified enero 2025
Hi @Mariano_Colmenarejo , big thanks! It works now perfectly! I am not sure how to send the CLI pairing logs. I turned this on in the driver setting but not sure where to take it from. Pls advice. thx
You can send driver logs by downloading the ST CLI to your Linux/Windows/macOS computer and using the command βsmartthings edge:drivers:logcatβ and selecting his driver.
No!
Letβs say, if I use the physical switch 98% it update the status in the app.
But main problem when I use the app to turn on/off, some of the switches donβt respond and the button in the app keep rotate in loop till I get the error message.
If I try again, immediately, most of the times it yes response.
Itβs not a specific switch, it happens randomly
