Thank you very much. Unfortunately, I am still unable to connect. I wonder if there is something wrong with my Aeotec v3 hub? I have tried two different LeakSmart valves (v1 and v2) with frequent resets. They appear to be connecting to Zigbee according to their flashing lights, but I get connection error 34-302 if pre-selecting the valve, or if I search for devices, I get nothing. I have also observed that I seem to be unable to access the SmartThings “stock drivers,” in that every other Z-wave and Zigbee device I have connected has its own driver from an optionally subscribed channel, including SmartThings (beta). When I try to change driver, I am never offered the option of a stock driver. I guess my next step is an inquiry to SmartThings.
Hi @rich7
Install Zigbee thing Mc driver from my channel and pair with it to see your device fingerprints
they may be different from the ones in the drivers. With the groovy dth it did not matter, now it is essential that they be identical
@Mariano_Colmenarejo I installed your Zigbee Lock Drivers (Thank you so much!). I have a couple Kwikset 914 Zigbee locks.Once I uninstalled them and re-installed with your drivers, LUM now recognizes them and I’m able to manage user codes. However the user codes don’t show under lock details so I’m not able to create notifications for each user code like i can with my Schlage z-wave lock. Any insight on this?
Hi @Joseph_Ong
This device was added to the driver, but it didn’t work correctly and it was left unfixed since I don’t have the device and I can’t debug it. I’m going to remove it from the driver
You can try this other driver that should work
Thanks @Mariano_Colmenarejo. Tried that. But also can’t work.
Did you uninstall and reinstall the device directly with the driver to get it set up?
possibly the driver change is not enough to configure it
according to the post if it works for some user
Thanks! Let me keep trying. The pause button can’t work hence a big issue for me. Thanks for your help.
Where are the default routines (for example, Opening detection notifications in the Zigbee Contact Mc driver) specified in the driver code? I’m interested in adding additional templates.
To emit the opne and close events the driver uses the zigbee contactSensor_defaults.lua that are in the default libraries of the Hub firmware.
If you want to handle them manually to modify something you must copy the code of that default library in the driver and configure a call to those functions copied in the driver template zigbee_handlers.
You can look at the subdriver code “co-handler
/init.lua” of the Zigbee Smoke/CO Detector Mc driver.
You will see that they are the same as the contact sensor defaults but they emit capabilities.carbonMonoxideDetector events instead of capabilities.contactSensor.contact events
Hi @Mariano_Colmenarejo, could you please add the device below to zigbee window treatment?
This device uses the EF00 cluster.
It might work with the @iquix driver if their fingerprints are added.
You can also try to use @w35l3y EF00 cluster driver.
Sorry this device doesn’t work with any of my drivers
I have nothing for multiple zigbee buttons
You can try @ygerlovin driver. Here is his channel:
https://api.smartthings.com/invitation-web/accept?id=b119aed9-4083-46bc-bc16-584b9d738abe
Zigbee Button Remote Driver [YG]
HI,
Can you please add the following Door Sensor to your Fingerprint file.
Door Sensor details.
Device ID: 6d66d5ed-ae53-4ac2-8f26-85ae0edff042
Manufacturer Code: TUYATEC-ydcwf5m2
Model: RH3001
These fingerprints were added at the beginning of August.
Install the Zigbee Contact Mc driver from my shared channel on your hub
Uninstall and reinstall the device with the app
Could you please add the Aqara Door and Window Sensor (Type “E1” Model number MCCGQ11LM - See listing on Amazon.uk). I can see in your zigbee-contact-mc-v3/fingerprints.yml file (snip below) that you already have listings for “Aqara Door and Window Sensor T1” and “Aqara Door and Window Sensor P1” type but not this “E1” type - I got the “E1” designation from this site in case it matters.
I think the info you need is:
DeviceLabel: Aqara Open/Closed Sensor
Manufacturer: LUMI
Model: lumi.sensor_magnet.aq2
Device name: contact-battery-profile
Many thanks.
deviceLabel: Aqara Door and Window Sensor T1
manufacturer: LUMI
model: lumi.magnet.agl02
deviceProfileName: contact-battery-profile
deviceLabel: Aqara Door and Window Sensor P1
manufacturer: LUMI
model: lumi.magnet.ac01
Added to this driver version, try if it works
Name Zigbee Contact Mc
Version 2023-08-28T17:39:57.603865056
- id: "LUMI/sensor_magnet.aq2"
deviceLabel: Aqara Door and Window Sensor E1
manufacturer: LUMI
model: lumi.sensor_magnet.aq2
