Manufacturer: LUMI
Model: lumi.plug.mmeu01
Server Cluster:
Ep: 0x01 =
{ 0000,0002,0003,0004,0005,0006,0009,0702,0B04 }
Client Clusters:
Ep: 0xF2 = { 0021 }
Ep:0x01 = { 000A,0019 }
the devices normally only send reports of the configured clusters and attributes.
The clusters of 0702 and 0B04 are configured in device pairing process.
If you paired device with a different driver, which I saw you asked about as well, and it doesn’t configure the 0702 and 0B04, when you change to a different driver, the device may not configured correctly to works with new driver.
Make a reset of the device and pair it directly with my driver and if you want you can send me the log.
If you are using beta firmware 49.7 on your hub, it is possible that when you change from @veonua’s driver to mine, the clusters and power and energy attributes are not configured.
So you should reinstall the device directly with the driver
Since I have both driver installed… How can I choose which driver to pair with? I need @veonua driver for other devices I already have. What do you think ?
Try to install driver with CLI after driver change from the veonua driver.
Can you send me a log when change from veonua driver? to see if the problem is the lifecycle init not preformed
This is the LOG when switching from @veonua driver to your driver:
Divisors are correctly read from the device and saved.
2023-08-13T20:58:44.341156407+00:00 PRINT Zigbee Switch Power Mc <<< Custom divisor handler >>>
2023-08-13T20:58:44.344429615+00:00 PRINT Zigbee Switch Power Mc SIMPLE_METERING_DIVISOR_KEY >>>> 1000
2023-08-13T20:58:44.344883407+00:00 PRINT Zigbee Switch Power Mc ELECTRICAL_MEASUREMENT_DIVISOR_KEY >>>>> 10
2023-08-13T20:58:44.345576365+00:00 DEBUG Zigbee Switch Power Mc מנורת לילה שי device thread event handled
It sends the configuration for power (activePower) and responds attribute is: ConfigureReportingResponseRecord || ZclStatus: UNREPORTABLE_ATTRIBUTE
2023-08-13T20:58:41.470161740+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: af91a300-a826-4af9-a8cd-d77c25146414 [0x6CE5] (מנורת לילה שי)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6CE5, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x6F, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNREPORTABLE_ATTRIBUTE, direction: 0x00, attr_id: 0x050B > > > >
According to the configuration accepted by the device, it should emit energy (CurrentSummationDelivered) and not emit power (activePower)
Has this device ever worked fine with this driver a time ago?
You can try to delete with the app and then put in pairing mode and add with search nearby to see if it pairs with the last paired driver instead of veonua driver
Correct, I’m getting Energy reading and not power
I think… when using DHT , this device worked correctly. Long time ago
This didn’t worked, again the device picked @veonua driver.
I’ll try to temporary move all paired @veonua devices , do Zigbee Thing MC, remove his driver, pair this device and hopefully this time and will pick your driver… I’ll let you know…
Paring with Zigbee Switch Power MC (@veonua driver removed) LOG:
Still no power. No Energy as well… How long to wait ?
I also received the following which I think is Xiaomi Specific Cluster 0xFCC0 , that might also contain power and energy:
2023-08-14T04:34:30.803575114+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T04:34:43.590521574+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2023-08-14T04:34:58.787328277+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T04:34:58.788405447+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: d9f0b07d-900d-4423-a78f-7adcc8d04be9 [0x3F55] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x3F55, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFF, rssi: -57, body_length: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x08, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x00F7, DataType: OctetString, OctetString: "\x64\x10\x01\x03\x28\x1F\x98\x39\x29\x5C\x67\x40\x95\x39\xCA\x62\x56\x42\x96\x39\x00\xA0\x0C\x45\x97\x39\x89\x88\x80\x41\x05\x21\x01\x00\x9A\x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x00\x0B\x0B\x20\x00\x9B\x10\x01" > > > >
2023-08-14T04:34:58.793533756+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
every time you mention someone here the person receives a email.
I’ll remove your fingerprint from the switch driver today.
Hi.
Nothing?
Driver fingerprints are updated, now
@Mariano_Colmenarejo
According to:
Seems that this device worked fine, there is a DTH there. Maybe can help…
Try this version that reads the activePower attribute as in other devices that do not report periodically.
Sorry, I am not going to implement aqara’s specific cluster management
Name Zigbee Switch Power Mc
Version 2023-08-14T18:54:09.582424562
Still no Electrical Metrics (Power or Energy). I change to ON at end of pairing.
You are the expert, I think that cluster: AnalogInput , AttributeId: 0x0055 is related to power.
It gives some info, that you didn’t emit.
LOG
2023-08-14T19:41:07.097749080+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2023-08-14T19:41:07.115420330+00:00 TRACE Zigbee Switch Power Mc Zigbee Device: 2774e8a6-d599-4b87-8449-b1025dec0686
Manufacturer: LUMI Model: lumi.plug.mmeu01
[1]: server: Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalMeasurement | client: Time, OTAUpgrade [242]: server | client: 0x0021
2023-08-14T19:41:07.115980913+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received lifecycle event: added
2023-08-14T19:41:07.116960788+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2023-08-14T19:41:07.117609996+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received lifecycle event: doConfigure
2023-08-14T19:41:07.122049538+00:00 TRACE Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received unhandled lifecycle event: added
2023-08-14T19:41:07.124020496+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:07.130235371+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:07.130685830+00:00 PRINT Zigbee Switch Power Mc <<< custom configure >>>
2023-08-14T19:41:07.131341121+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:07.131985455+00:00 DEBUG Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2023-08-14T19:41:07.137543496+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:07.818526663+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:07.820554288+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFE, rssi: -56, body_length: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x03, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x00F7, DataType: OctetString, OctetString: “\x64\x10\x00\x03\x28\x20\x98\x39\x00\x00\x00\x00\x95\x39\x1F\x70\x56\x42\x96\x39\x00\x20\x0F\x45\x97\x39\x00\x00\x00\x00\x05\x21\x01\x00\x9A\x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x00\x08\x0B\x20\x00\x9B\x10\x01” > > > >
2023-08-14T19:41:07.856467663+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.175608080+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2023-08-14T19:41:08.176201621+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received lifecycle event: infoChanged
2023-08-14T19:41:08.180212330+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:08.184870080+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10.0
2023-08-14T19:41:08.185634080+00:00 PRINT Zigbee Switch Power Mc << Preference changed: randomMax old value: nil new Value: 10.0
2023-08-14T19:41:08.186506955+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2023-08-14T19:41:08.187165955+00:00 PRINT Zigbee Switch Power Mc << Preference changed: onTime old value: nil new Value: 10
2023-08-14T19:41:08.187953080+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= Plug
2023-08-14T19:41:08.188805580+00:00 PRINT Zigbee Switch Power Mc << Preference changed: changeProfileEner old value: nil new Value: Plug
2023-08-14T19:41:08.193532496+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2023-08-14T19:41:08.198718413+00:00 PRINT Zigbee Switch Power Mc << Preference changed: groupAdd old value: nil new Value: 0.0
2023-08-14T19:41:08.199405330+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2023-08-14T19:41:08.202507580+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 255
2023-08-14T19:41:08.203205788+00:00 PRINT Zigbee Switch Power Mc << Preference changed: restoreState old value: nil new Value: 255
2023-08-14T19:41:08.203851871+00:00 PRINT Zigbee Switch Power Mc <<< Write restore state >>>
2023-08-14T19:41:08.204493371+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, DataType: Enum8, data: 0xFF > > > >
2023-08-14T19:41:08.216835330+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, DataType: Enum8, data: 0x02 > > > >
2023-08-14T19:41:08.224052455+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2023-08-14T19:41:08.224740121+00:00 PRINT Zigbee Switch Power Mc << Preference changed: electricalMeasureDiviso1 old value: nil new Value: 0.0
2023-08-14T19:41:08.225443413+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0605 > > >
2023-08-14T19:41:08.245197580+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]=
2023-08-14T19:41:08.245964830+00:00 PRINT Zigbee Switch Power Mc << Preference changed: version old value: nil new Value:
2023-08-14T19:41:08.246764371+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0
2023-08-14T19:41:08.247627955+00:00 PRINT Zigbee Switch Power Mc << Preference changed: localTimeOffset old value: nil new Value: 0
2023-08-14T19:41:08.248288871+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2023-08-14T19:41:08.248939913+00:00 PRINT Zigbee Switch Power Mc << Preference changed: randomMin old value: nil new Value: 1.0
2023-08-14T19:41:08.249582955+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2023-08-14T19:41:08.254007080+00:00 PRINT Zigbee Switch Power Mc << Preference changed: groupRemove old value: nil new Value: 1.0
2023-08-14T19:41:08.254837246+00:00 PRINT Zigbee Switch Power Mc Remove Groups >>>>>>>>>>>>>>>>>
2023-08-14T19:41:08.255751413+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2023-08-14T19:41:08.268326663+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2023-08-14T19:41:08.276520163+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2023-08-14T19:41:08.277342746+00:00 PRINT Zigbee Switch Power Mc << Preference changed: offTime old value: nil new Value: 10
2023-08-14T19:41:08.278214996+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2023-08-14T19:41:08.278882830+00:00 PRINT Zigbee Switch Power Mc << Preference changed: simpleMeteringDivisor1 old value: nil new Value: 0.0
2023-08-14T19:41:08.279531413+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD051, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0302 > > >
2023-08-14T19:41:08.297332163+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= No
2023-08-14T19:41:08.297929621+00:00 PRINT Zigbee Switch Power Mc << Preference changed: signalMetricsVisibles old value: nil new Value: No
2023-08-14T19:41:08.298806496+00:00 PRINT Zigbee Switch Power Mc Device ID <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)>
2023-08-14T19:41:08.299471580+00:00 PRINT Zigbee Switch Power Mc Manufacturer >>> LUMI Manufacturer_Len >>> 4
2023-08-14T19:41:08.300120121+00:00 PRINT Zigbee Switch Power Mc Model >>> lumi.plug.mmeu01 Model_len >>> 16
2023-08-14T19:41:08.300750080+00:00 PRINT Zigbee Switch Power Mc Memory >>>>>>> 1153.103515625 Kbytes
2023-08-14T19:41:08.314349955+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.314940455+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.315877913+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.318519746+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.319215371+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -56, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x4E, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x10, group_list_length: 0x00 > > >
2023-08-14T19:41:08.339462621+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:08.343494580+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2023-08-14T19:41:08.345109080+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2023-08-14T19:41:08.356045663+00:00 PRINT Zigbee Switch Power Mc All Deleted
2023-08-14T19:41:08.357304830+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”},“capability_id”:“legendabsolute60149.getGroups”}
2023-08-14T19:41:08.360149371+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.405761996+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.411062788+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -56, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4F, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x4003 > > > >
2023-08-14T19:41:08.411866621+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.424716663+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.425504413+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -56, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x50, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x8002 > > > >
2023-08-14T19:41:08.439648830+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.468347996+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.487423246+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xFF, rssi: -56, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x51, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0605, ZclStatus: SUCCESS, DataType: Uint16, ACPowerDivisor: 0x000A > > > >
2023-08-14T19:41:08.564543038+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:08.565032705+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
2023-08-14T19:41:08.566606205+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.727912996+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.735922330+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFE, rssi: -56, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x52, ZCLCommandId: 0x03 >, < RemoveGroupResponse || status: 0x8B, group_id: 0x0001 > > >
2023-08-14T19:41:08.776231871+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.817713080+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.818205621+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFD, rssi: -56, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x53, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x10, group_list_length: 0x00 > > >
2023-08-14T19:41:08.822191288+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:08.825124663+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2023-08-14T19:41:08.826776788+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2023-08-14T19:41:08.828150955+00:00 PRINT Zigbee Switch Power Mc All Deleted
2023-08-14T19:41:08.829329580+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”},“capability_id”:“legendabsolute60149.getGroups”}
2023-08-14T19:41:08.872126038+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:08.893738538+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:08.895757163+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xFE, rssi: -57, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x54, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0302, ZclStatus: SUCCESS, DataType: Uint24, Divisor: 1000 > > > >
2023-08-14T19:41:08.932145496+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:08.932639413+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
2023-08-14T19:41:08.934113330+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:09.121293288+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:09.123438830+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -57, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x02FFFF00 > > > >
2023-08-14T19:41:09.179982580+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:09.184695788+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T19:41:09.186424080+00:00 PRINT Zigbee Switch Power Mc <<<<< Emit on_off >>>>>>
2023-08-14T19:41:09.187580121+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/14 Time: 19:41
DNI: 0xD051 LQI: 255 RSSI: -57dbm
”},“capability_id”:“legendabsolute60149.signalMetrics”,“visibility”:{“displayed”:false}}
2023-08-14T19:41:09.297850496+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“state”:{“value”:“off”},“capability_id”:“switch”}
2023-08-14T19:41:09.353777496+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:09.877394205+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:09.878227538+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0xFD, rssi: -58, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x05, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0207, DataType: Boolean, Boolean: true > > > >
2023-08-14T19:41:09.883750163+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:10.243981747+00:00 PRINT Zigbee Switch Power Mc <<< Custom divisor handler >>>
2023-08-14T19:41:10.245895913+00:00 PRINT Zigbee Switch Power Mc SIMPLE_METERING_DIVISOR_KEY >>>> 1000
2023-08-14T19:41:10.248629122+00:00 PRINT Zigbee Switch Power Mc ELECTRICAL_MEASUREMENT_DIVISOR_KEY >>>>> 10
2023-08-14T19:41:10.249070580+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:10.302257163+00:00 PRINT Zigbee Switch Power Mc <<< Custom divisor handler >>>
2023-08-14T19:41:10.303906580+00:00 PRINT Zigbee Switch Power Mc SIMPLE_METERING_DIVISOR_KEY >>>> 1000
2023-08-14T19:41:10.306626747+00:00 PRINT Zigbee Switch Power Mc ELECTRICAL_MEASUREMENT_DIVISOR_KEY >>>>> 10
2023-08-14T19:41:10.307072497+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:35.676137750+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2023-08-14T19:41:41.808801459+00:00 TRACE Zigbee Switch Power Mc Received event with handler capability
2023-08-14T19:41:41.810389167+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received command: {“component”:“main”,“args”:{},“positional_args”:{},“command”:“on”,“capability”:“switch”}
2023-08-14T19:41:41.811361709+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:41.826716417+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:41.827185792+00:00 TRACE Zigbee Switch Power Mc Received event with handler capability
2023-08-14T19:41:41.828345625+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received command: {“component”:“main”,“args”:{},“positional_args”:{},“command”:“on”,“capability”:“switch”}
2023-08-14T19:41:41.838800875+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:41.839251792+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:41.917612834+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:41.918331792+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x55, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-08-14T19:41:41.927128917+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:41.929790709+00:00 INFO Zigbee Switch Power Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-08-14T19:41:41.934089334+00:00 PRINT Zigbee Switch Power Mc <<< GlobalCommand Handler >>>
2023-08-14T19:41:41.934898292+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”},“capability_id”:“switch”}
2023-08-14T19:41:41.940578+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/14 Time: 19:41
DNI: 0xD051 LQI: 255 RSSI: -58dbm
2023-08-14T19:41:41.955576167+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:41.956292292+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:41.957083042+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFE, rssi: -58, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x06, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x07000055 > > > >
2023-08-14T19:41:41.969449750+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:41.974455542+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T19:41:41.975516542+00:00 PRINT Zigbee Switch Power Mc <<<<< Emit on_off >>>>>>
2023-08-14T19:41:41.976330709+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/14 Time: 19:41
DNI: 0xD051 LQI: 254 RSSI: -58dbm
2023-08-14T19:41:41.983566750+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”},“capability_id”:“switch”}
2023-08-14T19:41:41.997607167+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:41.998060084+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:41.998863709+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFD, rssi: -58, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x56, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-08-14T19:41:42.007919750+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:42.008643875+00:00 INFO Zigbee Switch Power Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-08-14T19:41:42.012637167+00:00 PRINT Zigbee Switch Power Mc <<< GlobalCommand Handler >>>
2023-08-14T19:41:42.013529750+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”},“capability_id”:“switch”}
2023-08-14T19:41:42.018286875+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/14 Time: 19:41
DNI: 0xD051 LQI: 253 RSSI: -58dbm
2023-08-14T19:41:42.032038292+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:42.032751375+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:42.033403125+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFE, rssi: -58, body_length: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x07, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x00F5, DataType: Uint32, Uint32: 0x07000056 > > > >
2023-08-14T19:41:42.043631417+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch_power
2023-08-14T19:41:42.048821459+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-08-14T19:41:42.049842167+00:00 PRINT Zigbee Switch Power Mc <<<<< Emit on_off >>>>>>
2023-08-14T19:41:42.050493625+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/08/14 Time: 19:41
2023-08-14T19:41:42.055240834+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”},“capability_id”:“switch”}
2023-08-14T19:41:42.060909209+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2023-08-14T19:41:49.726448001+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2023-08-14T19:41:49.727359918+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 2774e8a6-d599-4b87-8449-b1025dec0686 [0xD051] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD051, src_endpoint: 0x15, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: AnalogInput >, lqi: 0xFF, rssi: -57, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x08, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0055, DataType: SinglePrecisionFloat, PresentValue: (1 + 0.154000) * 2^(3) > > > >
I don’t see anything in these logs and it seems to me that they are not with the new version of the driver
That’s what I have
28 Zigbee Switch Power Mc 7fee6e41-26cc-49ef-b1f4-b30a43e02fe6 2023-08-14T18:54:09.582424562 c8bb99e1-04a3-426b-9d94-2d260134d624
Hi. I have an older model 888000 LeakSMART valve that will not connect using your driver.
It formerly worked with this Groovy driver:
https://raw.githubusercontent.com/mleibman/SmartThingsPublic/a5bc475cc1b2edc77e4649609db5833421ad7f48/devicetypes/smartthings/zigbee-valve.src/zigbee-valve.groovy
In that driver, the two fingerprint profileIDs are:
“0104”, inClusters: “0000, 0001, 0003, 0004, 0005, 0006, 0008, 000F, 0020, 0B02”, outClusters: “0003, 0019”, manufacturer: “WAXMAN”, model: “House Water Valve - MDL-TBD”, deviceJoinName: “Waxman House Water Valve”
and
“0104”, inClusters: “0000, 0001, 0003, 0006, 0020, 0B02, FC02”, outClusters: “0019”, manufacturer: “WAXMAN”, model: “leakSMART Water Valve v2.10”, deviceJoinName: “leakSMART Valve”
The second may be the one you have already implemented.
Apparently, one version of this valve also has fingerprint:
“0104”, inClusters: “0000, 0001, 0003, 0004, 0005, 0006, 0020, 0B02, FC02”, outClusters: “0003,0019”, manufacturer: “WAXMAN”, model: “House Water Valve - MDL-TBD”, deviceJoinName: “Leaksmart Water Valve v1”// Lowes version
Sorry that I am not more familiar with fingerprinting.
Might these fingerprints be added to your driver?
Thank you.
Hi @rich7
These three models are on the Zigbee Valve stock controller
- id: WAXMAN/leakSMARTValve/v2.10
deviceLabel: leakSMART Valve
manufacturer: WAXMAN
model: leakSMART Water Valve v2.10
deviceProfileName: valve-battery-powerSource
- id: WAXMAN/HouseWaterValve/MDL-TBD
deviceLabel: Waxman Valve
model: House Water Valve - MDL-TBD
- id: WAXMAN/HouseWaterValve/MDL-8810300L
model: House Water Valve - MDL-8810300L
In my version of the driver this model: House Water Valve - MDL-8810300L was missing and I have added it too
Name Zigbee Valve Mc
Version 2023-08-15T09:06:26.324205384
@Mariano_Colmenarejo Could you add to this driver this gas sensor
