Edge Driver for Namron AS Zigbee 8 channel switch 4512772 / 4512773
I have created a simple edge driver for the Namron AS Zigbee 8 channel switch, or as it is called in Norwegian Namron Zigbee Kanalbryter Hvit/Sort sold by https://www.elektroimportoren.no/
Model number 4512772 (white). I assume it will also work for 4512773 (black) but have not tested it.
Nice it worked for my back version but i dont Get any response when i push the bottons On the switch. Any idea What That might be?
I’m sorry to hear that. Perhaps the black edition is slightly different from my white. I only have the one device, so not able to test it. But if you like you can go through the code on github and see if I made any mistakes.
Looks like there’s an error in the fingerprints. The deviceProfileName of the black one = the white one. As far as I know ST is dependent on device profiles to interpret its devices, and this might cause faulty status reports. I can test it for you if you’d like to push an update :slight_smile:
@kmhuglen any updates on the black device?
I have this one, in white
https://www.elektroimportoren.no/namron-zigbee-kanalbryter-hvit/4512772/Product.html
and assigning your device driver worked, however i get no traffic / inputs from any buttons or other signs of life other than that it reports 100% battery. Please give me some tips :slight_smile:
