[EDGE] [ALPHA] Nexia One Touch nx1000
I would appreciate if someone could write an edge driver for this device nexia one touch nx1000 zwave remote. There used to be an old device handler for this device. https://darwinsden.com/nexia-one-touch-nx1000-review-smartthings/
Hi @Aburd
If you are willing to send information about whether it works or not and help in debugging, then I can create a TEST driver with the functions of the 15 buttons, with the actions β€œpushed”, β€œheld”, β€œdown_hold” like the DTH .
I’m not saying this for you, but I’m a little tired of doing things and then some users not even having the education to answer, not only for me, but for other possible users of the forum.
Yes i can send information.
Ok
When I started creating the profile I realized that there is a limit of 10 components per profile and to create and display the 15 buttons I would need 16 components in the profile.
I have created the profile with the 16 components and it has not given me any errors, but it may not work in the App
Hi @nayelyz Please, Are the limits of 10 components per profile and 20 capabilities per component in use?
Created a TEST driver with 15 buttons and main, which will emit the same events that any of the 15 buttons emit.
Try it, the most that can happen is that not all the buttons are shown. I have tested with drivers that exceeded the limits and nothing is damaged.
I have looked for the fingerprints codes on the internet, I hope they are correct, otherwise it will not be matched
 Name         Z-Wave Button Mc-TEST
 Version      2023-09-06T17:14:02.406244179
- id: 0178/5343/4735
    deviceLabel: Nexia NX-1000
    manufacturerId: 0x0178
    productType: 0x5343
    productId: 0x4735
    deviceProfileName: multi-button-15
Do you have this published or do i need to go to the cli and do it. I do have the cli installed but i dont really know how to use it yet.
Sorry, I forgot publish it :man_facepalming:
Published now
Just got it installed. When any of the buttons are pressed only the first one registers as pressed. Im not sure if possible with the new edge system but on the old dth you used to be able to update what the screen said.
Let’s go in order, can you see the 15 buttons in the App?
You would have to send me the lod with the CLI, when you press button 1 and then button 2, to see what the device is sending
this is a tutorial to install cli and capture logs
That uses command classes that are not implemented in the firmware and I don’t know how to do it.
Yes can see all 15 buttons in the app. Here is the log. It would be awesome if someone could get the display working as that was one of my favorite features of this button.
2023-09-07T11:44:22.819521817+00:00 TRACE Z-Wave Button Mc-TEST Received event with handler unnamed
2023-09-07T11:44:22.878690817+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> received Z-Wave command: {args={key_attributes=β€œKEY_PRESSED_1_TIME”, scene_number=1, sequence_number=231, slow_refresh=false}, cmd_class=β€œCENTRAL_SCENE”, cmd_id=β€œNOTIFICATION”, dst_channels={}, encap=β€œNONE”, payload=β€œ\xE7\x00\x01”, src_channel=0, version=3}
2023-09-07T11:44:22.890555483+00:00 TRACE Z-Wave Button Mc-TEST Found ZwaveDispatcher handler in zwave_button
2023-09-07T11:44:22.909040817+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> emitting event: {β€œattribute_id”:β€œbutton”,β€œstate”:{β€œvalue”:β€œpushed”},β€œstate_change”:true,β€œcapability_id”:β€œbutton”,β€œcomponent_id”:β€œmain”}
2023-09-07T11:44:22.920774817+00:00 DEBUG Z-Wave Button Mc-TEST Nexia One Touch Controller device thread event handled
2023-09-07T11:44:26.696835819+00:00 TRACE Z-Wave Button Mc-TEST Received event with handler unnamed
2023-09-07T11:44:26.708471819+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> received Z-Wave command: {args={key_attributes=β€œKEY_PRESSED_1_TIME”, scene_number=2, sequence_number=232, slow_refresh=false}, cmd_class=β€œCENTRAL_SCENE”, cmd_id=β€œNOTIFICATION”, dst_channels={}, encap=β€œNONE”, payload=β€œ\xE8\x00\x02”, src_channel=0, version=3}
2023-09-07T11:44:26.715711819+00:00 TRACE Z-Wave Button Mc-TEST Found ZwaveDispatcher handler in zwave_button
2023-09-07T11:44:26.749611819+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> emitting event: {β€œattribute_id”:β€œbutton”,β€œstate”:{β€œvalue”:β€œpushed”},β€œstate_change”:true,β€œcapability_id”:β€œbutton”,β€œcomponent_id”:β€œmain”}
2023-09-07T11:44:26.762215152+00:00 DEBUG Z-Wave Button Mc-TEST Nexia One Touch Controller device thread event handled
2023-09-07T11:44:54.705892499+00:00 TRACE Z-Wave Button Mc-TEST Received event with handler unnamed
2023-09-07T11:44:54.718470832+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> received Z-Wave command: {args={key_attributes=β€œKEY_PRESSED_1_TIME”, scene_number=1, sequence_number=233, slow_refresh=false}, cmd_class=β€œCENTRAL_SCENE”, cmd_id=β€œNOTIFICATION”, dst_channels={}, encap=β€œNONE”, payload=β€œ\xE9\x00\x01”, src_channel=0, version=3}
2023-09-07T11:44:54.730817832+00:00 TRACE Z-Wave Button Mc-TEST Found ZwaveDispatcher handler in zwave_button
2023-09-07T11:44:54.731637165+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> emitting event: {β€œattribute_id”:β€œbutton”,β€œstate”:{β€œvalue”:β€œpushed”},β€œstate_change”:true,β€œcapability_id”:β€œbutton”,β€œcomponent_id”:β€œmain”}
2023-09-07T11:44:54.749320832+00:00 DEBUG Z-Wave Button Mc-TEST Nexia One Touch Controller device thread event handled
2023-09-07T11:44:55.868373166+00:00 TRACE Z-Wave Button Mc-TEST Received event with handler unnamed
2023-09-07T11:44:55.869754499+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> received Z-Wave command: {args={key_attributes=β€œKEY_PRESSED_1_TIME”, scene_number=2, sequence_number=234, slow_refresh=false}, cmd_class=β€œCENTRAL_SCENE”, cmd_id=β€œNOTIFICATION”, dst_channels={}, encap=β€œNONE”, payload=β€œ\xEA\x00\x02”, src_channel=0, version=3}
2023-09-07T11:44:55.890323499+00:00 TRACE Z-Wave Button Mc-TEST Found ZwaveDispatcher handler in zwave_button
2023-09-07T11:44:55.896035166+00:00 INFO Z-Wave Button Mc-TEST <ZwaveDevice: f3cd83ce-e1b4-4daa-b4b9-10ff7e02fb0a [1C] (Nexia One Touch Controller)> emitting event: {β€œattribute_id”:β€œbutton”,β€œstate”:{β€œvalue”:β€œpushed”},β€œstate_change”:true,β€œcapability_id”:β€œbutton”,β€œcomponent_id”:β€œmain”}
2023-09-07T11:44:55.901880166+00:00 DEBUG Z-Wave Button Mc-TEST Nexia One Touch Controller device thread event handled
Just checked the original dth the author put the command classes as a note. There might be more info in the original dth
 // Command structure - see http://z-wave.sigmadesigns.com/wp-content/uploads/2016/08/SDS12652-13-Z-Wave-Command-Class-Specification-N-Z.pdf
        //   "92" // COMMAND_CLASS_SCREEN_MD
        //   "02" // SCREEN_MD_REPORT
        //   "3B" // MoreData=0, Reserved=0, ScreenSettings=7 (3 bit, 7=keep current content), CharacterEncoding=1 (3 bit, ASCII+OEM)
        //   "1"  // LineSettings=0 (3 bit, 0=selected font), Clear=1 (1 bit, 1=clear line)
        //   "X"  // LineNumber (hex, 4 bit)
        //   "00" // CharacterPosition (hex 8 bit)
        //   "XX" // NumberOfCharacters (hex 8 bit)
        //   "XX" // Character (hex ASCII)
        // NOTE: Theoretically you can send more than one line in one screenMdReport command.
        //   Hoever, the zwave documentation says that the size of the payload SHOULD NOT be bigger than 48 bytes.
        //   That basically limits us to about 2 words at once.
        //   So, it's easier to send one button label at a time.
@Aburd
Install this driver with CLI command smartthings edge:drivers:install
Uninstall device
Prepare the CLI to capture the device installation log to see how it is configured
Reinstall with this new version
 Version      2023-09-07T12:28:57.0624015
I already read DTH, that’s why I told you that this command class is not defined in the hub firmware libraries and I would have to generate all the code manually and I’m sorry, but I’m not going to do it, first because I don’t know how to do it and I don’t have time either now to learn it
Here is the device installation log with the new driver installed. I couldn’t post the full thing here so its on pasebin 2023-09-07T12:52:10.669277714+00:00 TRACE Z-Wave Button Mc-TEST Setup driver zw - Pastebin.com
2023-09-07T12:52:10.669277714+00:00 TRACE Z-Wave Button Mc-TEST  Setup driver zwave_button with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_button
  default_handlers:
    driverSwitched:
    doConfigure:
    added:
  child_dispatchers:
    DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button
      default_handlers:
        init:
      child_dispatchers:
        DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
          default_handlers:
            doConfigure:
          child_dispatchers:
        DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
          default_handlers:
            doConfigure:
          child_dispatchers:
        DeviceLifecycleDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
          default_handlers:
            doConfigure:
          child_dispatchers:
2023-09-07T12:52:10.703782714+00:00 TRACE Z-Wave Button Mc-TEST  Setup driver zwave_button with Capability handlers:
CapabilityCommandDispatcher: zwave_button
  default_handlers:
    refresh:
      refresh
  child_dispatchers:
    CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button
      default_handlers:
      child_dispatchers:
        CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
          default_handlers:
          child_dispatchers:
        CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
          default_handlers:
          child_dispatchers:
        CapabilityCommandDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
          default_handlers:
          child_dispatchers:
2023-09-07T12:52:10.704831381+00:00 TRACE Z-Wave Button Mc-TEST  Setup driver zwave_button with Z-Wave handlers:
ZwaveDispatcher: zwave_button
  default_handlers:
    BATTERY:
      REPORT
    NOTIFICATION:
      REPORT
    CENTRAL_SCENE:
      NOTIFICATION
    WAKE_UP:
      NOTIFICATION
    SCENE_ACTIVATION:
      SET
  child_dispatchers:
    ZwaveDispatcher: zwave_button -> Z-Wave multi button
      default_handlers:
        WAKE_UP:
          NOTIFICATION
        SCENE_ACTIVATION:
          SET
        CENTRAL_SCENE:
          NOTIFICATION
      child_dispatchers:
        ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Aeotec keyfob
          default_handlers:
            WAKE_UP:
              NOTIFICATION
          child_dispatchers:
        ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Fibaro keyfob
          default_handlers:
            WAKE_UP:
              NOTIFICATION
          child_dispatchers:
        ZwaveDispatcher: zwave_button -> Z-Wave multi button -> Aeotec Minimote
          default_handlers:
            WAKE_UP:
              NOTIFICATION
            BASIC:
              SET
          child_dispatchers:
2023-09-07T12:52:10.844073047+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave Device: 1223f123-e4ef-4db9-92d2-2135dc6f7351
Manufacturer: 0x0178 Product Type: 0x5343 Product ID: 0x4735
        [0]: ZWAVEPLUS_INFO, ASSOCIATION, ASSOCIATION_GRP_INFO, BATTERY, CENTRAL_SCENE, CONFIGURATION, DEVICE_RESET_LOCALLY, FIRMWARE_UPDATE_MD, MANUFACTURER_SPECIFIC, MULTI_CMD, POWERLEVEL, SCENE_CONTROLLER_CONF, SCREEN_ATTRIBUTES, SCREEN_MD, VERSION, WAKE_UP
2023-09-07T12:52:10.847275381+00:00 TRACE Z-Wave Button Mc-TEST  Received event with handler _resync
2023-09-07T12:52:10.869346381+00:00 TRACE Z-Wave Button Mc-TEST  Received event with handler environment_info
2023-09-07T12:52:10.870174047+00:00 DEBUG Z-Wave Button Mc-TEST  Z-Wave hub node ID environment changed.
2023-09-07T12:52:10.929972047+00:00 TRACE Z-Wave Button Mc-TEST  Found DeviceLifecycleDispatcher handler in zwave_button -> Z-Wave multi button
2023-09-07T12:52:10.933812381+00:00 DEBUG Z-Wave Button Mc-TEST  Nexia NX-1000 device thread event handled
2023-09-07T12:52:10.939755714+00:00 TRACE Z-Wave Button Mc-TEST  Received event with handler environment_info
2023-09-07T12:52:11.007609381+00:00 TRACE Z-Wave Button Mc-TEST  Received event with handler device_lifecycle
2023-09-07T12:52:11.019250714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> received lifecycle event: added
2023-09-07T12:52:11.031203047+00:00 TRACE Z-Wave Button Mc-TEST  Found DeviceLifecycleDispatcher handler in zwave_button2023-09-07T12:52:11.049537714+00:00 TRACE Z-Wave Button Mc-TEST  Found CapabilityCommandDispatcher handler in zwave_button
2023-09-07T12:52:11.068192714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(028b4e94) queued for radio transmission: CC:Battery, CID:0x02
2023-09-07T12:52:11.069110381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={}, cmd_class="BATTERY", cmd_id="GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-09-07T12:52:11.087088381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button2","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.122978047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button2","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.143033047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button9","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.175953381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button9","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.207214714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"main","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":15},"visibility":{"displayed":false}}
2023-09-07T12:52:11.236776381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(028b4e94) transmit status: TRANSMIT_COMPLETE_OK
2023-09-07T12:52:11.242809381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"main","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.260652047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button11","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.281924381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button11","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.298626047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button1","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.314324714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button1","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.330183047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button8","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.346307047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button8","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.362577047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button7","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.377879047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button7","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.393905714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button5","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.410225381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button5","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.426224381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button14","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.441614381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button14","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.458096714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button10","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.474207381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button10","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.493195381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button3","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.508670714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button3","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.525186714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button4","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.541916047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button4","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.557536047+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button15","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.573726048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button15","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.590529714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button13","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.605859381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button13","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.621678048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button12","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.638405381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button12","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.654211381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button6","attribute_id":"numberOfButtons","capability_id":"button","state":{"value":1},"visibility":{"displayed":false}}
2023-09-07T12:52:11.670502048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> emitting event: {"component_id":"button6","attribute_id":"supportedButtonValues","capability_id":"button","state":{"value":["pushed","held","down_hold"]},"visibility":{"displayed":false}}
2023-09-07T12:52:11.692904048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(3b239d50) queued for radio transmission: CC:Association, CID:0x01
2023-09-07T12:52:11.693830048+00:00 PRINT Z-Wave Button Mc-TEST  table_node_ids >>>>>> {        1       }
2023-09-07T12:52:11.698768714+00:00 PRINT Z-Wave Button Mc-TEST  <<<< _node_ids 1
2023-09-07T12:52:11.699923714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={1}}, cmd_class="ASSOCIATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01", src_channel=0, version=1}
2023-09-07T12:52:11.711809048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(cc786f4b) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.712805048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=1, scene_id=1}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x01\x01\x00", src_channel=0, version=1}
2023-09-07T12:52:11.728067381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(6a0cd303) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.728983381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=2, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x02\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.745668048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(1a9b7ad7) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.755868048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=2, scene_id=2}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x02\x02\x00", src_channel=0, version=1}
2023-09-07T12:52:11.760892048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(8f2f18e0) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.762141381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=3, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x03\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.778520381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(ffcd5e13) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.779483048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=3, scene_id=3}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x03\x03\x00", src_channel=0, version=1}
2023-09-07T12:52:11.793167381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(39489c20) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.794056714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=4, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x04\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.810138381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(d772a406) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.811065714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=4, scene_id=4}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x04\x04\x00", src_channel=0, version=1}
2023-09-07T12:52:11.825994714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(317edfad) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.826886048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=5, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x05\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.841085048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(0813de76) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.842009381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=5, scene_id=5}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x05\x05\x00", src_channel=0, version=1}
2023-09-07T12:52:11.853028714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(3b239d50) transmit status: TRANSMIT_COMPLETE_OK
2023-09-07T12:52:11.904022048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(0505407f) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.904971048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=6, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x06\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.918929381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(fb59ab47) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.919853381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=6, scene_id=6}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x06\x06\x00", src_channel=0, version=1}
2023-09-07T12:52:11.935249381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(49c57483) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.936179714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=7, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x07\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.950177381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(e19ef9af) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.951090381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=7, scene_id=7}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x07\x07\x00", src_channel=0, version=1}
2023-09-07T12:52:11.966505381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(e8eead5d) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:11.975221381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=8, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x08\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:11.980459381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(915236ce) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:11.982531381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=8, scene_id=8}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x08\x08\x00", src_channel=0, version=1}
2023-09-07T12:52:11.997015381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(cc786f4b) transmit status: TRANSMIT_COMPLETE_OK
2023-09-07T12:52:12.003258048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(5b084065) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.004150048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=9, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x09\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.017073048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(01b988cb) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.018860714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=9, scene_id=9}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x09\x09\x00", src_channel=0, version=1}
2023-09-07T12:52:12.033980048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(88052430) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.034903381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=10, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0A\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.049486048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(86be3e56) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.050398714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=10, scene_id=10}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0A\x0A\x00", src_channel=0, version=1}
2023-09-07T12:52:12.064333048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(36c1bdf6) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.065254714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=11, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0B\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.079784381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(b00c19f7) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.080702048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=11, scene_id=11}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0B\x0B\x00", src_channel=0, version=1}
2023-09-07T12:52:12.098089048+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(92a8278e) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.099168714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=12, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0C\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.113264381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(ab80f412) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.114152381+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=12, scene_id=12}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0C\x0C\x00", src_channel=0, version=1}
2023-09-07T12:52:12.129597714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(ef88706f) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.130521714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=13, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0D\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.143746381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(6f2231f5) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.144629714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=13, scene_id=13}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0D\x0D\x00", src_channel=0, version=1}
2023-09-07T12:52:12.159737381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(cdf5cea6) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.160806714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=14, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0E\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.173602381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(64e87f8f) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.184278714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=14, scene_id=14}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0E\x0E\x00", src_channel=0, version=1}
2023-09-07T12:52:12.189850714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(92f89e6f) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.192288048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=15, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.203097381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(6a0cd303) transmit status: TRANSMIT_COMPLETE_OK
2023-09-07T12:52:12.211931381+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(e9c5eeeb) queued for radio transmission: CC:2D, CID:0x01
2023-09-07T12:52:12.212813048+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={dimming_duration=0, group_id=15, scene_id=15}, cmd_class="SCENE_CONTROLLER_CONF", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x0F\x0F\x00", src_channel=0, version=1}
2023-09-07T12:52:12.228067714+00:00 TRACE Z-Wave Button Mc-TEST  Z-Wave command(0165b0f0) queued for radio transmission: CC:Configuration, CID:0x04
2023-09-07T12:52:12.228986714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> sending Z-Wave command: {args={configuration_value=0, default=false, format=0, parameter_number=16, size=1}, cmd_class="CONFIGURATION", cmd_id="SET", dst_channels={}, encap="AUTO", payload="\x10\x01\x00", src_channel=0, version=3}
2023-09-07T12:52:12.249900714+00:00 PRINT Z-Wave Button Mc-TEST  Memory >>>>>>> 1587.01953125    Kbytes
2023-09-07T12:52:12.250740048+00:00 DEBUG Z-Wave Button Mc-TEST  Nexia NX-1000 device thread event handled
2023-09-07T12:52:12.251886381+00:00 TRACE Z-Wave Button Mc-TEST  Received event with handler device_lifecycle
2023-09-07T12:52:12.253178714+00:00 INFO Z-Wave Button Mc-TEST  <ZwaveDevice: 1223f123-e4ef-4db9-92d2-2135dc6f7351 [1C] (Nexia NX-1000)> received lifecycle event: doConfigure
Just checked looks like all the buttons are working with this new driver :grinning: I do hope that someone out there eventually makes a driver that can use the screen.
I’m glad it works.
The held and relesed event should also work.
I am going to merge it with the Mc driver and you will only have to change to the Mc driver.
I have seen in the logs that the wake Up interval is 4200 sec. If you see it shown offline before those 4200 sec it could be reduced.
Pressed and held down events work for the held it does work but it doesn’t seem possible to trigger without also doing held down but that just seems to be a device limitation
TEST driver merged to Z-Wave Button Mc
Tomorrow i will delete TST version from channel
 Version      2023-09-07T14:33:47.435485679
