Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Try the new cross-platform PowerShell Search - Microsoft Bing
PS C:\WINDOWS\system32> cd \smartthings
PS C:\smartthings> .\smartthings.exe edge:drivers:logcat
? Enter hub IP address with optionally appended port number: 10.200.10.182
Driver Id Name
1 ba2e6153-ff84-4921-b57a-bb19d4dc9387 Z-Wave Button Mc
2 0f206d13-508e-4342-9cbb-937e02489141 Z-Wave Lock
3 2cbf55e3-dbc2-48a2-8be5-4c3ce756b692 Z-Wave Switch
4 ce930ffd-8155-4dca-aaa9-6c4158fc4278 Zigbee Lock
? Select a driver. 1
connecting… connected
2023-04-02T16:46:19.434910798+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T16:46:19.435595247+00:00 INFO Z-Wave Button Mc <ZwaveDevice: dc01de49-d019-4d6d-aac4-6fd2899f7fcf [4C] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: removed
2023-04-02T16:46:19.436599287+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: dc01de49-d019-4d6d-aac4-6fd2899f7fcf [4C] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: removed
2023-04-02T16:46:19.437433411+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:46:19.438082003+00:00 TRACE Z-Wave Button Mc Received event with handler driver_lifecycle
2023-04-02T16:46:19.438694822+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.047112174+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with lifecycle handlers:
DeviceLifecycleDispatcher: zwave_button
default_handlers:
driverSwitched:
added:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
doConfigure:
child_dispatchers:
2023-04-02T16:47:45.051427591+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Capability handlers:
CapabilityCommandDispatcher: zwave_button
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
child_dispatchers:
2023-04-02T16:47:45.052001966+00:00 TRACE Z-Wave Button Mc Setup driver zwave_button with Z-Wave handlers:
ZwaveDispatcher: zwave_button
default_handlers:
BATTERY:
REPORT
NOTIFICATION:
REPORT
CENTRAL_SCENE:
NOTIFICATION
WAKE_UP:
NOTIFICATION
SCENE_ACTIVATION:
SET
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button
default_handlers:
SCENE_ACTIVATION:
SET
CENTRAL_SCENE:
NOTIFICATION
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Fibaro keyfob
default_handlers:
child_dispatchers:
ZwaveDispatcher: zwave_button → Z-Wave multi button → Aeotec Minimote
default_handlers:
BASIC:
SET
child_dispatchers:
2023-04-02T16:47:45.104112341+00:00 TRACE Z-Wave Button Mc Z-Wave Device: 1437112a-a5fd-4679-a240-fb4de0a39460
Manufacturer: 0x011A Product Type: 0x0801 Product ID: 0x0B03
[0]: SCENE_CONTROLLER_CONF, ASSOCIATION, VERSION, MANUFACTURER_SPECIFIC
2023-04-02T16:47:45.114527341+00:00 TRACE Z-Wave Button Mc Received event with handler _resync
2023-04-02T16:47:45.115052716+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T16:47:45.124266174+00:00 TRACE Z-Wave Button Mc Z-Wave command(1df6465d) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.124984841+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button → Z-Wave multi button
2023-04-02T16:47:45.125602549+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=1, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x01”, src_channel=0, version=1}
2023-04-02T16:47:45.140032508+00:00 TRACE Z-Wave Button Mc Z-Wave command(0ec6a015) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.141752049+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=2, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x02”, src_channel=0, version=1}
2023-04-02T16:47:45.157855258+00:00 TRACE Z-Wave Button Mc Z-Wave command(b814892a) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.158346549+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=3, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x03”, src_channel=0, version=1}
2023-04-02T16:47:45.169137508+00:00 TRACE Z-Wave Button Mc Z-Wave command(c630ca57) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.174979008+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=4, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x04”, src_channel=0, version=1}
2023-04-02T16:47:45.194390883+00:00 TRACE Z-Wave Button Mc Z-Wave command(3cbc5d1a) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.194909216+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=5, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x05”, src_channel=0, version=1}
2023-04-02T16:47:45.203607633+00:00 TRACE Z-Wave Button Mc Z-Wave command(1d02d97f) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.207357466+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=6, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x06”, src_channel=0, version=1}
2023-04-02T16:47:45.225370633+00:00 TRACE Z-Wave Button Mc Z-Wave command(1df6465d) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.230638466+00:00 TRACE Z-Wave Button Mc Z-Wave command(20328fa2) queued for radio transmission: CC:Association, CID:0x01
2023-04-02T16:47:45.231119383+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> sending Z-Wave command: {args={grouping_identifier=7, node_ids={}}, cmd_class=“ASSOCIATION”, cmd_id=“SET”, dst_channels={}, encap=“AUTO”, payload=“\x07”, src_channel=0, version=1}
2023-04-02T16:47:45.241774383+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.244197633+00:00 TRACE Z-Wave Button Mc Received event with handler environment_info
2023-04-02T16:47:45.245896883+00:00 DEBUG Z-Wave Button Mc Z-Wave hub node ID environment changed.
2023-04-02T16:47:45.275714216+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T16:47:45.280789633+00:00 TRACE Z-Wave Button Mc Z-Wave command(0ec6a015) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.285241924+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: added
2023-04-02T16:47:45.288396341+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T16:47:45.290224424+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T16:47:45.296125549+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.305099049+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button3”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.314498091+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.322206716+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button2”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.331352508+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.341192841+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button6”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.350905049+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.358941133+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button5”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.368261674+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.376754883+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button4”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.386242508+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:7},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.394223633+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“main”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.403461216+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.412076299+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button1”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.422927716+00:00 TRACE Z-Wave Button Mc Z-Wave command(b814892a) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.425871966+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“numberOfButtons”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:1},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.433829258+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> emitting event: {“attribute_id”:“supportedButtonValues”,“capability_id”:“button”,“component_id”:“button7”,“state”:{“value”:[“pushed”]},“visibility”:{“displayed”:false}}
2023-04-02T16:47:45.448616049+00:00 PRINT Z-Wave Button Mc Memory >>>>>>> 1496.0263671875 Kbytes
2023-04-02T16:47:45.449328091+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.452824883+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T16:47:45.453479841+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: doConfigure
2023-04-02T16:47:45.461703341+00:00 TRACE Z-Wave Button Mc Found DeviceLifecycleDispatcher handler in zwave_button
2023-04-02T16:47:45.462182008+00:00 TRACE Z-Wave Button Mc Found CapabilityCommandDispatcher handler in zwave_button
2023-04-02T16:47:45.466435508+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.473586758+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.509433341+00:00 TRACE Z-Wave Button Mc Z-Wave command(c630ca57) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.613538758+00:00 TRACE Z-Wave Button Mc Z-Wave command(3cbc5d1a) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.650545299+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T16:47:45.652227383+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T16:47:45.657062799+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T16:47:45.675484466+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
2023-04-02T16:47:45.709413633+00:00 TRACE Z-Wave Button Mc Z-Wave command(1d02d97f) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:47:45.809386133+00:00 TRACE Z-Wave Button Mc Z-Wave command(20328fa2) transmit status: TRANSMIT_COMPLETE_OK
2023-04-02T16:48:49.799832015+00:00 TRACE Z-Wave Button Mc Received event with handler device_lifecycle
2023-04-02T16:48:49.800421265+00:00 INFO Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received lifecycle event: infoChanged
2023-04-02T16:48:49.801921599+00:00 TRACE Z-Wave Button Mc <ZwaveDevice: 1437112a-a5fd-4679-a240-fb4de0a39460 [4D] (ZWNSC7 Enerwave Scene Master)> received unhandled lifecycle event: infoChanged
2023-04-02T16:48:49.803247599+00:00 DEBUG Z-Wave Button Mc ZWNSC7 Enerwave Scene Master device thread event handled
