I keep getting flood reminders for a test on the flood sensor I ran several hours ago. Is there a way to dismiss it? It’s a great feature but I can’t stop it from updating me. I’m using an older version of the iPhone app
In the ST app go to Smart Home Monitor. Then click on the red alert. This will allow you to dismiss the alert.
Users should also be aware that if you don’t dismiss an incident, subsequent leaks will not close the valve (assuming you opened it after the first leak)
Same goes for intrusions on SHM.
