I’m trying to cross-compile the st-device-sdk-c for OpenWRT (Omega2) and it fails compiling mbedtls/bignum.c
I don’t want to use mbedtls and I’d rather use openssl available in OpenWRT, but I can’t get around compiling it, and compiling it throws a bunch of “invalid operands” errors.
[ 8%] Building C object src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/bignum.c.o
mipsel-openwrt-linux-gcc: warning: environment variable 'STAGING_DIR' not defined
{standard input}: Assembler messages:
{standard input}:191: Error: invalid operands `lw $10,36($sp)'
{standard input}:192: Error: invalid operands `lw $11,32($sp)'
{standard input}:193: Error: invalid operands `lw $12,40($sp)'
{standard input}:194: Error: invalid operands `lw $13,28($sp)'
{standard input}:195: Error: invalid operands `lw $14,0($10)'
{standard input}:196: Error: invalid operands `multu $13,$14'
{standard input}:197: Error: unrecognized opcode `addi $10,$10,4'
{standard input}:198: Error: invalid operands `mflo $14'
{standard input}:584: Error: invalid operands `sw $11,32($sp)'
{standard input}:585: Error: invalid operands `sw $10,36($sp)'
src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/build.make:230: recipe for target 'src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/bignum.c.o' failed
make[2]: *** [src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/bignum.c.o] Error 1
CMakeFiles/Makefile2:321: recipe for target 'src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/all' failed
make[1]: *** [src/deps/mbedtls/mbedtls/library/CMakeFiles/mbedcrypto.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Is there a solution?
