Dimming can't be controlled on Innr zigbee bulb
Hi all. I purchased a couple Innr color-temperature-adjustable light bulbs. The Innr site claims complete compatibility with Smartthings. While I can turn it on and off and control the color temperature, I can’t control dimming. After a random amount of time, it will eventually dim itself to 10% and remain there. The only way I’ve found to be able to adjust the dimming is to use the Advanced web interface and use the SetLevel command.
I contacted Innr and they said, “Ya, that’s a common problem. We’ll send you a free hub.” But I don’t want another hub and another app. I want to figure out how to make this work with Smartthings natively. I’ve also tried the MC edge driver, but that made things even worse.
Has anyone had any luck getting these bulbs to function fully? The model number is RB 272 T.
Thank you!
I use ZigBee Bulb by Iquix driver with my innr bulbs.
Invitation on this page.
Or here
Wonderful! That fixed it!
Thanks Andrew!
