I was experimenting with some community drivers on one of my dimmers.
When I decided to go back to a ST driver, I have noticed that the interface is no longer the same as it used to be.
Upon checking device profiles, it became apparent that the dimmer got its profile somehow changed. I did factory reset and re-aded the device multiple times, nothing helped. How do I say the device that it should be Light?
âLightâ is a device name, not a profile, and with Edge drivers the name is set at device creation to the initial implicit device profile name. It is read-only and pretty useless. I suspect it is a relic of the old platform where it also didnât do much.
Have you had these devices a long time? Long enough to have been migrated from the old Groovy platform perhaps? Only it looks like your old devices were recognised as lights, whereas the device is now assumed to be a switch and migration might be the reason.
The only difference in the actual profiles is the Category. If you change the device icon you should be able to influence that.
Correction: It used to be the case that changing a device icon in the mobile app might also add or change the user category. So for example choosing a door icon for a contact sensor added the use category âDoorâ. Back in March this year it was observed that this no longer happened. Iâd forgotten about that.
Well, the capabilities displayed seem to be identical. The fact that the mobile app design elements are slightly different doesnât change the functionality.
It is not recognized as âlightsâ. The one with the updated UI is using the switch-level profile and the other one is using the on-off-level profile. They both have the exact same capabilities with the only difference being the default name assigned to the device during onboarding:
Yes, sorry about that. It used to be the case that changing the device icon using the mobile apps would in some cases add an extra category of type âuserâ that would override the default âmanufacturerâ category assigned in the device profile. So this meant that, for example, a contact sensor device could have an additional category such as âDoorâ.
I made a comment to this effect on a thread back in March and it was pointed out that this was no longer happening and changing icons would set any âuserâ category type to the default. This may have been because it was conflicting with the summary tiles which use categories to identify which devices to work with, or it could have been because it doesnât really bear close scrutiny as in the case of the example a door might have a contact sensor but it might have other properties too.
The mobile app has only started tarting up what it assumes to be the key attribute of a device component comparatively recently. Given the assumption is often completely wrong one would hope there might be further changes to come.
This device and driver are intended for energy measurements. Energy measurements can be placed in St App own room, for example. In principle, devices can be operated from these measuring devices if you make enough routines or Rules API rules to control them.
