Device Handlers showing up as cloud
I have several devices in my ST Estate that use custom handers.
Ie GE Fan control
Dome Moisture Sensors
Dome Water Shut-off
Is there any way for these devices to be local or are they stuck using cloud?
any device that uses custom code will always be cloud. I don’t know of any device handlers for fan control that is local. for the Dome products, you can use the stock Z-Wave Water Sensor and Z-Wave Water Valve handlers that are local.
The zwave generic dimmer works for the fan controllers and runs local. It will just give you a slider and 0-33% is low, 34-67% is medium and 68-100% is high.
