2nd Dome Leak Sensor
Installed Dome Device Handler and App. Installed 1st sensor no problem. It is using the Dome Device Handler I installed. Now I want to install a 2nd sensor. SmartThings finds it but uses a generic Z-Wave Water Sensor handler rather than the the Dome Leak Sensor handler. How can I get it to use the Dome one. With Dome I can configure it to do things if a leak is discovered, which is highly desirable.
go to the device page in the IDE and change the Type assigned. Once you configure it, you may want to switch it back to the generic handler so it runs local.
That was the trick. I did the first one last summer and if I had to that then, it is a long lost memory.
