Yup - recommendation I got was to use this:
For what i am using it for, it is sufficient. I have not had any issues, and it did solve a polling problem for me that was killing my batteries.
Did you mean this version, or the beta version when you say āit is sufficient.ā ? Sounds like youāre saying that the beta version solved your polling problem, correct?
Yes, i am using the beta version. It has solved the polling problem for me.
JT
I am using an older smartthings V1 hub with a new Schlage Camelot Lock and I am having trouble getting it to properly connect and report current status. I have tried resetting the Schlage to default and removing it from smartthings and then re-adding it to the hub. It can lock and unlock the lock but status is always reported as unknown. Is this an issue because it is a v1 hub or what am I missing.
Thanks for any advise.
Iām doing something wrong. trying to add a second user, but under user setting it says WARNING: this user has been disabled. Reason: Code Conflict Detected. Any suggestion?
Thank you for you help
#beta v0.2
###Whatās new?
- Views for lock info to see what all the codes are in each slots.
- Overwrite mode option (ON by default) which removes codes that arenāt set by this app.
(I believe this will be very helpful to most people) REMEMBER TO DELETE any apps that also alter codes before using this app with this option enabled. You have been warned.
###Whatās Next? - Global Notifications/Schedule.
- Improve lock info pages and user views.
- stretch goal: Remove need for custom DTH for code reports.
If there are reasons that are holding you back from ditching the old app for this one, let me know so that I can prioritize what I work on in the future.
Hey Erik, great work! The big feature that I would need to switch to the new SmartApp would be full keypad integration. Iām currently using a custom version of your original version which extends keypad support to add keypad chime support.
Thanks! I donāt have a keypad to test out if I were to add this. Maybe another person could do a PR and add the feature after it goes to V1? I might buy a keypad though. Which one do you use?
I use the Xfinity keypad but the Loweās iris keypad is basically the same thing (both made by centralite). I think the Loweās one is currently on sale tooā¦
https://m.lowes.com/pd/Iris-White-Security-Alarm-Keypad-Works-with-Iris/999925326
Wow! Nice sale. Iāll pick one up this week.
Beware, the sale price varies by store. I could not find the 60% off price anywhere within 2 hours of my house.
Looks like I can order online and choose pickup in store. Bingo.
I tried that, they would not let me order for the discount from a remote store and pick up local. Howād you do it?
Hi ethayer, thank you so much for your work with this app. Smartthings support referred me to you. We are looking at using your app as a way to remotely change the code on our Kwikset Smartcode 909 lockset, while also using the Smartthings hub. Can you verify if this is possible with your app?
You sure can! Please consider using the new app for this. It is a lot more user friendly. Even though itās in āBetaā I believe it is better for new users.
Awesome!! Thanks for the quick response!
They seem to be doing an IP look up to set the discount value. Iām getting 15% - 60% depending on where I VPN into.
If you VPN into an area which has a larger discount, you can order at that price.
And pick it up at a different store? E.g., get the price at a store 2 hours away, but pick it up at a local store?
Yea, I think itās only based on IP address, so you could add it to your cart at that price and then choose whatever pickup store youād like.
At home, the discount is 60%. We have 2 networks at my workplace. One network yields a 40% discount and the other one shows a 15% discount.
If you have a VPN service you could probably bounce around and find where the 60% discount works for you then pickup at your local store.
Itās bad form to implement the discount in the way that they did IMO. If they want to target a store for a discount, they should have made you select your store before showing prices, or just set their discounts evenly through out their stores⦠though I get how a store in NYC couldnāt have the same prices as say⦠my home town.
EDIT: This may be against their TOS? A customer service rep should just give you the 60% discount if you make a small fuss. Best Buy got in a bit of trouble when customers discovered their besybuy.com intranet site was displaying store-based prices while their bestbuy.com internet site displayed internet prices (they would price match) and customers who saw an item at $20 online would be surprised to see the same item at $25 in store⦠then on the intranet site, they would see it was $25 āonlineā when they went to price-match.
