[DEPRECATED] Free Ecobee Suite, version: 1.5.*
@Jason_Bottjen
  • Please try running your refresh cycle at 3 (or 2 or 1) minutes…I’m looking to see if I screwed up something that might cause the retries to fail because they are spaced too far apart…
  • In preparation for (hopefully) catching the failure in Live Logging, please set your log-level to 5. This will maximize the error tracking…
  • You’ll need to set up Live Logging running in a browser pretty much 24x7 so that it is collecting data when the problem occurs…
Barry
Got it. I’ll see what I can do to get the live log.
(Sorry for the delayed response)… Yes, I have it working in 2 locations with 5 different thermostats.
What problems are you experiencing?
Could you add “Enable only for certain modes or programs” to Smart Mode? I only want the app to be active if I’m Home. Thanks!
So you set this to run only while Home or Night modes…what should happen when ST changes to Away while the system has been set to Off Mode? What about other mode changes it may have made.
I guess the safe thing is to put it in Auto Mode, and hope that your Goodbye! routine sets an appropriate setpoint? I’d hate to get into a “If it’s Off when I leave, do this, but if its Heat when I leave do that, if it is Cool when I leave do something else, and if its Auto when I leave don’t do anything…” It is complicated by the fact that Off can also be Fan Circulate only (in effect)…
First off great app!! So much better than the stock Ecobee app!
Everything is working well for me except for quiet time. I’m on 15.02 and it just isn’t working with my house Fan switch. HVAC isn’t going to off when switch is on. So issue seems to be trigger I am guessing. My switch is Levitron.
Any one else having issues with quiet time on a
switch?
Thanks,
Brian
I am preparing a new release of the entire Suite - I’ll go double check that Quiet Time is working before I release it (you will be able to install on top of your existing installation).
Found the problem - new version coming up Very Soon.
With the release of Ecobee Suite v1.6.*, this thread is no longer active:
Thanks for the update…it’s been working well over the last 2 days…
