I’ve been working on manually converting my “Smart lighting” automations to Routines because the Sunrise/Sunset feature stopped working in “Smart lighting.”
I normally use a Routine because of the flexibility it provides. But I just discovered that there is some extremely limited On and Off functionality at the Device. I tried it out on my Fountain Device, but found it does not have a Sunrise or Sunset based timer option, so I created two Routines for Fountain on and Fountain off.
Here’s the problem. I cannot find a way to delete the two Routines that were created at the Device. There is no Delete at the Fountain Device or at the Routine.
How do I delete these two unwanted Routines circled in red in the image and keep the two unhighlighted Fountain Routines named “Fountain 1: On and Fountain 2: Off?
Those look like the ones that are created by setting the power on/off in the Routines tab for the device. Go to that tab and disable power on/off. Then go to the Automations tab and long press on the specific Routine and the delete option should appear.
They’ve actually removed Delete from the Edit section of devices as well. Long press is the thing for those as well. I think they are trying to emulate iOS behavior.
