Current state of Edge integration for IKEA devices?
I’m using a few IKEA controllers with varying success. I’ve tried searching the threads, but a lot of discussions I’ve found seem either old or inconclusive. I’m wondering if there’s a summary of where the device integrations are at today, or if there’s any advice for better/updated drivers I should be using?
At the moment, I’m using:
SYMFONISK Sound remote - This seems to be running off a default driver (there’s no option to select a specific driver), and now has a dimmer function (not working). When loading this device now, I receive the message “this device hasn’t updated all its status information yet. Check again later”, though it still appears to function.
TRÅDFRI Wireless dimmer - Currently running this with Zigbee Button + Groups - Alpha Test but I’m not getting battery updates. Same problem when using the default driver. Buttons work fine with either though.
STYRBAR Remote control - Using this with the [ST Edge] Virtual Things Edge Driver from ygerlovin and is the only one that seems to function as intended.
TRÅDFRI Wireless motion sensor - Running off the default driver. Seems to work ok, but the motion detected state stays active for a long time, making it problematic to use if coming back into a room before the state can reset.
I use @Mariano_Colmenarejo Zigbee Motion Sensor MC for my Ikea Motion sensor
Thanks! That’s the one from here - (EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices?
What benefit have you found using this over the default SmartThings driver?
that is the drivers. I am sure users have different experiences and opinions on drivers so my advice, try it for yourself. :slight_smile:
