I’d like my CT100 to set my Heat to 20F (effectively turning it off here in TX most of the year) whenever enabling AWAY mode. Should be a straight forward thing, my setup looks correct, and in Smart Things I get the correct notification “As you requested… I set the thermostat to 20 for heat”.
The problem is that’s just not working, the heat setting remains at 68F (which is where I keep it when I’m in HOME mode).
Some thermostats have a limit on how low/high you set them. I couldn’t find anything in the manual I have for what that might be for the CT100, but it might not change if the value is not possible for the thermostat to reach. Couldn’t you just change the thermostat mode to off when enabling AWAY mode using Core?
