The following community FAQ will give you the basic Terminology, concepts, and steps in the web interface.
[OBSOLETE] FAQ: An Overview of Using Custom Code in SmartThings (SmartThings Classic, Groovy Code)
If the custom DTH has the right model identifier, when you go to add it the device will probably pick it up. If it doesn’t, you have to manually change it via the web interface using the process described in the FAQ after you’ve added the device to the network.
