Correct Z-Wave Lock API Command
Not really my thing, but I find myself more intrigued by this code in the lock notification report …
st/zwave/defaults/lock.lua
          local lock_codes = device:get_field(constants.LOCK_CODES)
>8 – Snip a bit – >8
          local code_name = lock_codes[code_id] == nil and lock_codes[code_id] or "Code " .. code_id
          event["data"] = { codeId = code_id, codeName = code_name, method = event["data"].method}
I can’t get my head around how that code could be right. I want it to say ~= nil.
As it stands I see:
If the slot doesn’t have a name then use the name which it doesn’t have, but as it doesn’t have one use ‘Code x’.
If the slot does have a name then use ‘Code x’.
