Hi @nayelyz
the CLI command smartthings edge:drivers:delete not works for me.
The final message id driver xxxxxxxxx deleted, but the driver is not deleted
? Select a driver to delete. 41
Driver 5eb48fb1-4494-4604-b641-f56d7948dae4 deleted.
Hi @nayelyz
Are you using the command of edge:drivers
to see if they still appear or where did you see it still existed?
Yes, I have tried to delete it a lot of times and it still shows up in the list
I have also tried writing the Id after the command and it does the same.
I have updated to the latest version of the CLI in case it was something like this and it is still the same
I have tried deleting another driver and it works fine.
Sorry, So I can’t seem to delete this driver id 5eb48fb1-4494-4604-b641-f56d7948dae4
ok, can you share the latest timestamp when you tried to delete it, please? I will ask the team about that
Also, having access to your account is required in case the team needs to make some tests.
Where do I see the timestamp of when I try to delete a driver?
Oh, sorry for the confusion, it is only the approximate time when you executed the command, for example, 20:46 CET
Last deletion attempt, today 20:56 GMT
