I have a new ADT hub that is connected to my wifi. I would like to move the hub to a new wifi network. How do I go about changing the network config on the Smartthings Hub without loosing everything? This is an ADT Smartthings hub, not a hardwired hub.
If you go into the settings on the control panel (you will need to enter your master code) you should see a wireless networks menu. From here you can choose a new wifi network and connect to it. Simply changing WiFi networks will not cause you to lose everything. I just did this yesterday.
