In the old days (of the old app) I was able to easily find a way to change al my blue LED lights to turn on when the light was off and turn off when light is on. I am unable to find out how to do this with the new app. Since about 2/3 of my devices are set that way I’d ike to get the rest setup the same way. How?
What’s the brand and model of the devices? The method will vary.
Most commonly, the manufacturer has a parameter stored in the firmware of the switch which controls this. So the question is, how can you set the value of that parameter?
For zwave devices, there will be typically be a way to expose this parameter through an edge Driver, and then you can set it there. But some of them use a specific tap pattern on the switch itself to make the change.
But again, it all depends on the exact brand and model of the switch. ![]()
If you’re not sure what model it is, check the web interface to your account:
@JDRoberts
THe devices are the usual suspects for GE Zwave -
switch, dimmer and fan
GE 46201
GE 46203
GE 14287
Ok, try this edge driver. You can ask any further questions about that driver in that thread, and someone will help you there. ![]()
[ST Edge] Driver for GE/Jasco/Honeywell Z-Wave Switches, Dimmers, Fans, Outlets, and Plug-Ins
