Ceiling Fan/Light solution for ceiling fans with pull chains and no switch wiring? (2022)
Terrie thanks for all the help. Couple more questions:
  1. I am assuming this is Stock DTH - Device Third Party Handler for ST?
  2. Does ST have an edge driver for either the ZEN77 or ZEN34?
  3. What is the best driver for support/compatibility?
    a) Custom DTH
    b) Custom Edge Driver
    c) Stock Edge Driver
    d) Stock DTH
  4. Are you integrating ST and Bond via the app or the Cloud?
    a) If via the app what version?
    b) If via the cloud what version ST Hub V3?
  5. Did you use the [ST Edge] Local Bond Bridge Edge Driver [BETA] for this integration?
    [ST Edge] Bond Bridge LAN [BETA]
  6. Will this ZEN34 switch work with just the remote that you mention have above or will it also work the with the older Hampton Bay Zigbee Fan controller - #33 by dalec zigbee fan controller as well?
  7. What firmware version are you using on the ZEN34? v1.30 or 1.40?
Thanks,
Troy
