Project:
Make all of the fans and lights usable by a switch for my mom who cannot speak well after a stroke. Be able to automate fans and lights based on motion and temperature.
My Current Setup:
SmartThings v3 hub
Alexa
5 pull chain ceiling fans with dimmable lights
2 do not have wall switches
- installed RF remotes and linked with Bond
3 have wall switches
- switches are in 4 gang box, 4 gang box ,3 gang box
- smart wifi switches
- not compatible with ST but compatible with Alexa
I’m in the US
Problem 1
Bond does not allow remote control use or it becomes unsynced with actual status.
Mom can not use extended voice commands. She is limited to 1-2 simple word phrases. Alexa will not allow “On” or “Off” as a voice triggers (we tried light and dark which mom could do about half the time).
The upside of bond is it is compatible with ST and I have full automation control.
Problem 2
Mom can use the physical wifi wall switches.
I have limited automation control via Alexa.
I want to turn fans on automatically if temp gets above ‘x’. (I am trying to avoid IFTTT)
Partial solution
Thanks to @Automated_House, I discovered the ERIA smart dimmer remote. As a test I have it linked to one of my bond fans. I have it set as follows:
Button 1 - light on/off
Button 2 - fan Hi
Button 3 - fan Med
Button 4 - fan off
The light control isn’t perfect (it blinks on/off/on or off/on/off with button press) but it stays synced with Bond! I am already in communication with Adurosmart support
I have been looking at fan speed control and light dimming (in 1) switch option and have not found much.
The Homeseer switch was an option until I spoke with their support today and they said the device handlers for ST integration may stop working with no fix date yet.
The Inovelli switch was an option but I haven’t had any good luck with their products and read several reviews on a forum about multiple issues with the fan/light switch.
I am open to separating into 2 smart switches but that seems like it will get expensive quickly for all 3 fans.
Bottom line is that I will do what works best for my mom and sacrifice the automations if I have to but thought someone here might have some ideas I haven’t looked at yet or more in depth product knowledge than I do.
Open to suggestions
