Capability conflicts pt2
components:
- id: main
  capabilities:
  - id: temperatureMeasurement
    version: 1
  - id: thermostatHeatingSetpoint
    version: 1
  - id: thermostatCoolingSetpoint
    version: 1
  - id: thermostatMode
    version: 1
  - id: fanSpeed
    version: 1
  - id: thermostatOperatingState
    version: 1
  - id: fanOscillationMode
    version: 1
  categories:
  - name: Thermostat
- id: outdoor
  capabilities:
      version: 1
this profile fails to render in iOS,
conflicting row fanOscillationMode
Can you provide more info about this, @veonua, please?
Is the capability fanOscillationMode not showing or are there others?
it renders as an empty page without any capabilities on iOS. On the Android it renders ok, with ainor issue - modes are in lower case
Hi, @veonua.
Following up on this. Can you provide more details about your case, please?
I used the configuration you shared above and I can see the device on the iOS app correctly.
  • Which version of the app are you using?
  • Does this device have a special configuration? For example, in the device presentation
  • Are the capabilities initialized?
This is just to see if I can replicate the issue.
Also, it can help to clear the app’s cache, on iOS the only way to do this is by reinstalling the app.
sorry, probably there was a glitch with the profile.
Now, after many changes and numerous device recreation it renders ok on both iOS and Android
No problem. I’m glad it was just temporary. Thanks for the info!
