Hi everyone,
Im needing help with two issues im facing when applying a device config to my device profile.
I can’t seem to set the supported values for the thermostatMode capability. I want to limit the default list to auto, cool, heat, dry air, and fan only.
I have changed fanSpeed to 0 - 3 steps and renamed ‘Off’ to ‘Auto’. However i’m now trying to change the ‘Auto’ posiition to be an active state (like low, medium, and high, where the slider turns blue) instead of an inactive state where it is grey.
Can anyone see whats wrong with my device config below?
"version": "0.0.1",
"type": "profile",
"dashboard": {
"states": [
"component": "main",
"capability": "switch",
"version": 1,
"idx": 0,
"group": "main",
"values": [],
"composite": false
"actions": [
"version": 1,
"idx": 0,
"group": "main",
"inline": null
"basicPlus": []
"detailView": [
"version": 1,
"values": [],
"patch": []
"capability": "temperatureMeasurement",
"version": 1,
"values": [
"key": "temperature.value",
"enabledValues": [],
"label": "Ambient Temperature"
"patch": []
"capability": "thermostatCoolingSetpoint",
"version": 1,
"visibleCondition": {
"version": 1,
"value": "switch.value",
"operator": "EQUALS",
"operand": "on"
"values": [
"key": "coolingSetpoint.value",
"label": "Set Temperature",
"range": [
18,
30
"patch": []
"capability": "fanSpeed",
"version": 1,
"version": 1,
"operand": "on"
"values": [
"key": "setFanSpeed",
"label": "Fan",
"alternatives": [
"key": "0",
"value": "Auto",
"type": "active"
"key": "1",
"value": "Low",
"type": "active"
"key": "2",
"value": "Medium",
"type": "active"
"key": "3",
"value": "High",
"type": "active"
"range": [
0,
3
"patch": []
"capability": "thermostatMode",
"version": 1,
"values": [
"key": "thermostatMode.value",
"enabledValues": [
"auto",
"cool",
"heat",
"dry air",
"fan only"
"label": "Mode"
"patch": []
"capability": "refresh",
"version": 1,
"values": [],
"patch": []
"automation": {
"conditions": [
"version": 1,
"values": [],
"patch": [],
"exclusion": []
"version": 1,
"values": [
"patch": [],
"exclusion": []
"version": 1,
"values": [
"range": [
18,
30
"patch": [],
"exclusion": []
"version": 1,
"values": [
"label": "Fan",
"alternatives": [
"key": "0",
"value": "Auto",
"type": "active"
"key": "1",
"value": "Low",
"type": "active"
"key": "2",
"value": "Medium",
"type": "active"
"key": "3",
"value": "High",
"type": "active"
"range": [
0,
3
"patch": [],
"exclusion": []
"version": 1,
"values": [
"enabledValues": [
"auto",
"cool",
"heat",
"dry air",
"fan only"
"label": "Mode"
"patch": [],
"exclusion": []
"actions": [
"version": 1,
"values": [],
"patch": [],
"exclusion": []
"version": 1,
"values": [
"range": [
18,
30
"patch": [],
"exclusion": []
"version": 1,
"values": [
"label": "Fan",
"alternatives": [
"key": "0",
"value": "Auto",
"type": "active"
"key": "1",
"value": "Low",
"type": "active"
"key": "2",
"value": "Medium",
"type": "active"
"key": "3",
"value": "High",
"type": "active"
"range": [
0,
3
"patch": [],
"exclusion": []
"version": 1,
"values": [
"enabledValues": [
"auto",
"cool",
"heat",
"dry air",
"fan only"
"label": "Mode"
"patch": [],
"exclusion": []
"version": 1,
"values": [],
"patch": [],
"exclusion": []
