As the title suggests, finally i convinced my girlfriend to samsung
Now i try to invite her to smartthings but it keeps saying regions doesnt match
I came to canada from india, right after that i contacted samsung support got region switched to canada. So all good
My girlfriend made the new account in canada with first her first samsung (so region is canada)
Unless the procedure has changed… while Samsung may be able to change the location on the Samsung account… they can’t adjust it on the hub. The only way to resolve is to reset the hub and start fresh.
If that is indeed what you see, then your hub is still assigned to the previous region and you would need to reset. If not, you should contact ST support.
No , i actually moved to canada
Once im here i had requested for change of region, i was sent a form
After that, all of my purchases related to indian was deleted and changed to canada.
