Hi all - I have a SmartThings hub (IM6001-V3P01). I can see the hub as a connected device on my router, but the phone app is not detecting the hub. I also have routines that were set up with my previous phone that run as expected, so the hub itself seems to be functioning otherwise.
I’ve unplugged and restarted the hub, I don’t get the red and green blinking light I should expect. It blinks blue for a bit, then goes solid green. I was hoping not to factory reset the hub if possible so I don’t have to set up the routines again, but I’d appreciate any suggestions you have. Thanks!
