Pulling out my hear on this one… =) Brand new lock. Yale Touchscreen Deadbolt (220) with the Z-wave module. Hasn’t been installed before and I have followed the Smartthings instructions as well as the troubleshooting tips for locks, I made sure the hub is really close (within 1ft even). In the options menu on the lock I only get option 1 which is to join a network.I have also tried to completely reset the lock and start from scratch…
As I live in New Zealand, I bought my SmartThings hub from Amazon/US. The lock however is from NZ… is there an issue connecting Australian/New Zealand Z-wave devices to a US hub? No idea here but I can’t really come up with a solution.
Ah… so found all the articles about Z Wave Australia… and well… I have learnt something new. The frequency is indeed different. I guess I will have to see if I can buy a US z wave network module now. jeez.
But, would it be better to buy the Zigbee module? Is that the same everywhere?
as you now know the Australian frequency is 921.4 mhz and the US is 908.4 mhz so is incompatible, youve learnt the hard way that you should stick within your region when buying zwave equipment.
as you know the module in your smartlock is replaceable, i would not buy the zigbee module as apart from the fact that this works across regions within the 2.4ghz band (some regions have restrictions on signal strength only) SmartThings does not have a Device Handler for the lock using a zigbee module, my suggestion would be for you to buy a US Zwave module. obviously going forward for zwave devices you will need to buy only US Zwave modules. would be worth you setting up an account with one of the US drop shipping services that are available for shipping US products to different countries.
