Cant add Outlet to by Smartthings Hub?
Hi I bought a smartthings starter kit and I can’t get the Outlet to go into setup mode. All the set up instructions I’ve found online all show pictures of the outlet similar to mine but mine does not have a button on the top that, people are saying you use to go into set up mode.
Thanks in advance
As JD likes to say (and he’s right) Exact model number matters… Do you have any info about the manufacturer/model?
Usually with these it’s keep the button on the side pressed (either side!) while you power it up. Let go the button when the LED flashes and you’re good to go.
