am running a SmartThings Hub 2nd Generation.
I recently migrated to the new app. I can control all devices and everything works great.
The issue I have is that I cannot add devices while in the new app. When I try to add a device,:
- Getting everything ready
- Get started with your “device name”…I click “Start”
- Select a hub and room for your device
- Hub --> Select a Hub
- No Hub in your current location
- Room --> Select a Room
- Select a hub first
Try as I might, I can’t seem to figure out how to get buy this. If I try to add a new SmartThings hub, these areas are populated correctly. Any other device, and I can’t add as it stops here.
I can add a device in the IDE and it shows up in the old app new app.
I can add a device in the old app, and it shows up in the IDE and the new app.
I read online that this can happen when your hub isn’t in a room. I don’t even have a hub device to add into any room. How exactly do you get the hub to appear?
HELP!!!
