I have a house full of Leviton Z-Wave plugs and switches that have worked pretty well, but I tried adding two Leviton plugs recently (one brand new, one old one that I had around, two different revisions) and they exhibit the same behavior. The Smartthings Hub sees them, will give them a name, acts like they’re all set up, even logs all commands sent to and from them, but will never turn them on or off. If I try to turn them on/off from the main page of the Smartthings iOS app, it says it’s turning them on and off, but if I go to the actual device page it says it can’t connect to either device.
So that’s two different models of plug from the same brand, of which I have like five others, and they have the same odd non-functional behavior. I’m guessing that means something is wrong with my Hub, but I’m not sure what? I initially attempted to set one up across the house, but when it had this behavior I removed it, moved the plug and light to the same room as the Hub, and tried again just to get the same result.
Any help or advice you can give me would be very appreciated! Thanks.
