Hi,
have have a problem with my network. I accidentally clicked remove location in the app and with that reset the whole hub. I unfortunately did not remove all my nodes (Spruce sprinkler and several GE switched) from the network.
Now after I setup the Hub again, I can not add any of the nodes to the hub.
Is there a way to add the hub back to the old zwave network? Or is there a way to reset all the nodes?
Thanks, Tobias
bamarayne
2
Hi Tobias,
Unfortunately, that was one button you really didn’t want to click on and then approve…
You must now do a forced exclusion on every one of your devices. You will then have to reconnect them to the hub, one at a time. Then, you will need to reinstall all of your smartapps and rebuild all of your automations from scratch.
