Since that point I have reset the hub thinking I could just re-add devices. So far that hasn’t worked out.
I’ve added the hub to the app but am unable to add any devices manually or via automatic discovery. Also when I log on the graph.api.smartthings.com website it doesn’t show I have any hubs. When I look in the mobile app it shows I have an active hub. No idea where to go from here.
Probably for this issue you’ll have to work with SmartThings Support. A search of the forum should turn up a number of folks to have been in the same situation.
EDIT: Ooops! Re-read this. I originally thought you needed to get your hub back! The guys, below, are on the right track…
