I have a Connect Home Pro which I purchased in Canada a few years ago. Rencelty, i tried to connect it via the SmartThings app, but it returned me with the error code 36-302 or sometimes 36-201 and refused to connect to WiFi. I have tried to factory reset the model or unplug it, but it did not help.
I searched online, and it looks like it’s a problem where the device’s software is too old and cannot be connected to the SmartThings server.
WWouldservice centrebe able to update it’s software mannually?
Does that mean there is no way to add it back? I do not mind if the performance is not the best, but I would just like to have the option to connect my Wi-Fi router to my SmartThings.
Yes, a Samsung Service Centre or Samsung Experience Store can manually update the software by flashing the latest firmware onto your device using their internal technician tools (such as Net Odin). Error 36-302 occurs because the factory firmware on your Connect Home Pro (ET-WV530) is too outdated to communicate with the modern SmartThings cloud setup servers. If a service centre is unavailable, an alternative workaround is to temporally connect your unit as a sub-node to another user’s already-configured Connect Home router, which forces it to pull the latest over-the-air firmware update before you set it up independently HCTRA
