Bosch Motion Sensor (ISW-ZPR1-WP13) : Smartthings v2 hub
Hi @robert.haugen
Thanks for logs but, these logs do not clarify anything about the problem.
it is necessary to see the pairing logs of the device.
  • Leave logcat running for the driver.
  • Uninstall a device from the app
  • Add the device from app
  • When it is paired, the configuration logs of the clusters and attributes and the responses of the device to the configuration will appear.
  • That will show if the battery attribute has been set correctly.
To better see the logs, do not post with the developer format, it is easier for me to follow as they are shown in the CLI
2022-11-12T08:36:01.215962138+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T08:36:01.227952804+00:00 TRACE Zigbee Motion Sensor Mc Zigbee Device: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd
Manufacturer: Bosch Model: ISW-ZPR1-WP13
[5]: Basic, Identify, IASZone, PollControl, TemperatureMeasurement, PowerConfiguration, Diagnostics
2022-11-12T08:36:01.287951388+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received lifecycle event: added
2022-11-12T08:36:01.296791429+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T08:36:01.300165096+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received lifecycle event: doConfigure
2022-11-12T08:36:01.305037346+00:00 TRACE Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received unhandled lifecycle event: added
2022-11-12T08:36:01.308218013+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:01.314511513+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-11-12T08:36:01.318867929+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“Waiting Zigbee Message”},“visibility”:{“displayed”:false}}
2022-11-12T08:36:01.331596721+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:01.337788346+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion → MultiSensor
2022-11-12T08:36:01.340780929+00:00 PRINT Zigbee Motion Sensor Mc subdriver do_configure
2022-11-12T08:36:01.343712429+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T08:36:01.348067096+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T08:36:01.355838304+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T08:36:01.373939471+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: PowerConfiguration, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T08:36:01.382867888+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0021, DataType: Uint8, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x5460, reportable_change: 0x01 > > > >
2022-11-12T08:36:01.395327804+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: IASZone, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T08:36:01.425908638+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0002, DataType: Bitmap16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C > > > >
2022-11-12T08:36:01.441801846+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0010, DataType: IEEEAddress, data: D052A82640CD0001 > > > >
2022-11-12T08:36:01.449849888+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneEnrollResponse || EnrollResponseCode: SUCCESS, zone_id: 0x00 > > >
2022-11-12T08:36:01.456276763+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:01.474115346+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:01.479344638+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:01.918222138+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T08:36:01.924286346+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received lifecycle event: infoChanged
2022-11-12T08:36:01.935116304+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-11-12T08:36:01.938168971+00:00 PRINT Zigbee Motion Sensor Mc ***** infoChanged *********
2022-11-12T08:36:01.941301179+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 10 preferences: changeRep
2022-11-12T08:36:01.944362221+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> changeRep nil 10
2022-11-12T08:36:01.947513804+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T08:36:01.951901179+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T08:36:01.969640971+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T08:36:01.976359054+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= No preferences: signalMetricsVisibles
2022-11-12T08:36:01.979950763+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> signalMetricsVisibles nil No
2022-11-12T08:36:01.982890679+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 5 preferences: maxTime
2022-11-12T08:36:01.985931513+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> maxTime nil 5
2022-11-12T08:36:01.988916138+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T08:36:01.992813888+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T08:36:02.001629304+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD0A0, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T08:36:02.017896138+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= preferences: version
2022-11-12T08:36:02.020812013+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> version nil
2022-11-12T08:36:02.023774971+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 0.0 preferences: tempOffset
2022-11-12T08:36:02.027230846+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> tempOffset nil 0.0
2022-11-12T08:36:02.037820596+00:00 PRINT Zigbee Motion Sensor Mc Device ID >>> <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)>
2022-11-12T08:36:02.040713513+00:00 PRINT Zigbee Motion Sensor Mc Manufacturer >>> Bosch Manufacturer_Len >>> 5
2022-11-12T08:36:02.043544721+00:00 PRINT Zigbee Motion Sensor Mc Model >>> ISW-ZPR1-WP13 Model_len >>> 13
2022-11-12T08:36:02.047028013+00:00 PRINT Zigbee Motion Sensor Mc Memory >>>>>>> 1442.61328125 Kbytes
2022-11-12T08:36:02.049990388+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:02.055053679+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:02.816566679+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:02.864882429+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -40, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x7E >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T08:36:02.891630846+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:02.915990721+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:02.956745346+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xFF, rssi: -40, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x59, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2022-11-12T08:36:03.019748596+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:03.346712680+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:03.440024888+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:03.444305513+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -40, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x7F >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T08:36:03.454859055+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:03.609854055+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:03.614629096+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xFF, rssi: -40, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5A, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0021 > > > >
2022-11-12T08:36:03.624238346+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:04.792357971+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:04.796948555+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -41, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T08:36:04.807289096+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:04.811981930+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:04.889310638+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -41, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5B, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2022-11-12T08:36:04.898957888+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:04.902082721+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:04.907417930+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -40, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5C, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-11-12T08:36:04.917771930+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:04.920961513+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:04.926632930+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -40, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5D, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-11-12T08:36:04.937939388+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:05.055431805+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:05.069863138+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:05.074255180+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: OnOff >, lqi: 0xFF, rssi: -40, body_length: 0x0009, < ZDOMessageBody || < ZDOHeader || seqno: 0x03 >, GenericBody: FD FF 04 01 01 19 00 00 > >
2022-11-12T08:36:05.085055138+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:05.130338221+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:05.134995555+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -40, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0024, extended_status: 0x00, zone_id: 0x00, delay: 0x0039 > > >
2022-11-12T08:36:05.146615180+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-11-12T08:36:05.149574138+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-11-12T08:36:05.153645555+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-11-12T08:36:05.163786680+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:05.829731347+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:05.834112972+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -42, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x02 >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T08:36:05.848095388+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:07.070239263+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:07.074945513+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -41, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x60, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T08:36:07.085574680+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:07.189675722+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:07.194264930+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -41, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x61, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T08:36:07.204794388+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T08:36:07.600386347+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T08:36:07.604949430+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 29cf36b5-6938-4db9-b33a-dec76f8b2fbd [0xD0A0] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD0A0, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -41, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x62, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T08:36:07.615414013+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
It seems that the attribute 0x0020 (battery voltage) is not being configured.
The attribute 0x0021 (battery % remaining) is being configured, which this device does not support.
I have modified the driver and this version should work.
 Name         Zigbee Motion Sensor Mc
 Version      2022-11-12T10:25:43.709914085
You can install it using the CLI with the command smartthings edge:drivers:install
Thank you.
I installed the new version of the driver. Assigned. Rebooted hub. Still the same issue.
Tried to remove and pair the device again.
Confirmed that the driver is version 2022-11-12-T10:25
Thank you for the efford so far.
Didn’t you capture the logs?
The first battery event may take time to send.
You can perform a refresh command by sliding your finger down in the details view
2022-11-12T12:30:24.820137462+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:30:24.824960504+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: de255418-698c-45b4-a255-a416feb2f96a [0xBC89] (Bosch Motion Sensor Kjøkken)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xBC89, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xFF, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x5E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 2537 > > > >
2022-11-12T12:30:24.836205879+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion → MultiSensor
2022-11-12T12:30:24.839218004+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-11-12T12:30:24.886311379+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: de255418-698c-45b4-a255-a416feb2f96a [0xBC89] (Bosch Motion Sensor Kjøkken)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/12 Time: 12:30
DNI: 0xBC89 LQI: 255 RSSI: -53dbm
2022-11-12T12:30:24.897503379+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: de255418-698c-45b4-a255-a416feb2f96a [0xBC89] (Bosch Motion Sensor Kjøkken)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:25.37}}
2022-11-12T12:30:24.909096045+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor Kjøkken device thread event handled
2022-11-12T12:30:33.326163091+00:00 DEBUG Zigbee Motion Sensor Mc driver device thread event handled
2022-11-12T12:31:03.326212564+00:00 DEBUG Zigbee Motion Sensor Mc driver device thread event handled
2022-11-12T12:31:13.576464027+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:31:13.642402152+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x900E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xFF, rssi: -63, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x1B, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Int16, MeasuredValue: 1181 > > > >
2022-11-12T12:31:13.668777860+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion → MultiSensor
2022-11-12T12:31:13.682219485+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
2022-11-12T12:31:13.691882319+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/12 Time: 12:31
DNI: 0x900E LQI: 255 RSSI: -63dbm
2022-11-12T12:31:13.721239985+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> emitting event: {“attribute_id”:“temperature”,“capability_id”:“temperatureMeasurement”,“component_id”:“main”,“state”:{“unit”:“C”,“value”:11.81}}
2022-11-12T12:31:13.744868527+00:00 DEBUG Zigbee Motion Sensor Mc Garage device thread event handled
2022-11-12T12:31:27.170668158+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:31:27.175793242+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x900E, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -63, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x1C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0020 > > > >
2022-11-12T12:31:27.186415533+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-11-12T12:31:27.189542117+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-11-12T12:31:27.193335658+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-11-12T12:31:27.204349783+00:00 DEBUG Zigbee Motion Sensor Mc Garage device thread event handled
2022-11-12T12:31:27.419888075+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:31:27.424149325+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x900E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -63, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0x90 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2022-11-12T12:31:27.434230575+00:00 DEBUG Zigbee Motion Sensor Mc Garage device thread event handled
2022-11-12T12:31:29.426160576+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:31:29.431688160+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 57d5e204-753b-4467-91cc-0f0bec3a10d0 [0x900E] (Garage)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x900E, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: Basic >, lqi: 0xFF, rssi: -63, body_length: 0x000B, < ZDOMessageBody || < ZDOHeader || seqno: 0x91 >, GenericBody: 00 00 00 00 00 00 00 00 00 00 > >
2022-11-12T12:31:29.442499035+00:00 DEBUG Zigbee Motion Sensor Mc Garage device thread event handled
2022-11-12T12:31:33.332007911+00:00 DEBUG Zigbee Motion Sensor Mc driver device thread event handled
2022-11-12T12:31:59.623660007+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T12:31:59.635769216+00:00 TRACE Zigbee Motion Sensor Mc Zigbee Device: 6b194606-9620-484d-b544-7aa3e1105746
2022-11-12T12:31:59.638868507+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received lifecycle event: added
2022-11-12T12:31:59.694040382+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T12:31:59.697577674+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received lifecycle event: doConfigure
2022-11-12T12:31:59.702481924+00:00 TRACE Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received unhandled lifecycle event: added
2022-11-12T12:31:59.705461841+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:31:59.711432299+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-11-12T12:31:59.715540632+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“Waiting Zigbee Message”},“visibility”:{“displayed”:false}}
2022-11-12T12:31:59.731733049+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:31:59.737809424+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion → MultiSensor
2022-11-12T12:31:59.740774549+00:00 PRINT Zigbee Motion Sensor Mc subdriver do_configure
2022-11-12T12:31:59.743619549+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T12:31:59.747602507+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T12:31:59.756068466+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T12:31:59.774777924+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: PowerConfiguration, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T12:31:59.783974007+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0021, DataType: Uint8, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x5460, reportable_change: 0x01 > > > >
2022-11-12T12:31:59.792562549+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: IASZone, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T12:31:59.801819007+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0002, DataType: Bitmap16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C > > > >
2022-11-12T12:31:59.819607841+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0010, DataType: IEEEAddress, data: D052A82640CD0001 > > > >
2022-11-12T12:31:59.834468507+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneEnrollResponse || EnrollResponseCode: SUCCESS, zone_id: 0x00 > > >
2022-11-12T12:31:59.841136799+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:31:59.850539049+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:31:59.859174882+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:00.117911591+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler device_lifecycle
2022-11-12T12:32:00.136088841+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received lifecycle event: infoChanged
2022-11-12T12:32:00.147214841+00:00 TRACE Zigbee Motion Sensor Mc Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-11-12T12:32:00.150180841+00:00 PRINT Zigbee Motion Sensor Mc ***** infoChanged *********
2022-11-12T12:32:00.187743258+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 5 preferences: maxTime
2022-11-12T12:32:00.190770091+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> maxTime nil 5
2022-11-12T12:32:00.193778091+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T12:32:00.198568549+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T12:32:00.206771341+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T12:32:00.220633466+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 10 preferences: changeRep
2022-11-12T12:32:00.223673049+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> changeRep nil 10
2022-11-12T12:32:00.227856508+00:00 PRINT Zigbee Motion Sensor Mc maxTime y changeRep: 300 10
2022-11-12T12:32:00.232053924+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 00155F00B44CACB2, src_endpoint: 0x05, cluster: TemperatureMeasurement, dest_addr_mode: 0x03, dest_address: D052A82640CD0001, dest_endpoint: 0x01 > > >
2022-11-12T12:32:00.240952591+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x634D, dest_endpoint: 0x05, profile: 0x0104, cluster: TemperatureMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Int16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C, reportable_change: 10 > > > >
2022-11-12T12:32:00.257702633+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= preferences: version
2022-11-12T12:32:00.260608674+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> version nil
2022-11-12T12:32:00.263566799+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= 0.0 preferences: tempOffset
2022-11-12T12:32:00.266650466+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> tempOffset nil 0.0
2022-11-12T12:32:00.269571091+00:00 PRINT Zigbee Motion Sensor Mc device.preferences[infoChanged]= No preferences: signalMetricsVisibles
2022-11-12T12:32:00.277568049+00:00 PRINT Zigbee Motion Sensor Mc << Preference changed: name, old, new >> signalMetricsVisibles nil No
2022-11-12T12:32:00.284070549+00:00 PRINT Zigbee Motion Sensor Mc Device ID >>> <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)>
2022-11-12T12:32:00.287096091+00:00 PRINT Zigbee Motion Sensor Mc Manufacturer >>> Bosch Manufacturer_Len >>> 5
2022-11-12T12:32:00.290041508+00:00 PRINT Zigbee Motion Sensor Mc Model >>> ISW-ZPR1-WP13 Model_len >>> 13
2022-11-12T12:32:00.292917049+00:00 PRINT Zigbee Motion Sensor Mc Memory >>>>>>> 1433.06640625 Kbytes
2022-11-12T12:32:00.295832258+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:00.307332674+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:00.890027216+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:00.894376883+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -64, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x38 >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T12:32:00.904895966+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:01.039920591+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:01.045425216+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: TemperatureMeasurement >, lqi: 0xFF, rssi: -64, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x44, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2022-11-12T12:32:01.064505133+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:01.549925550+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:01.554096467+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -64, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x39 >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T12:32:01.565238550+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:01.569691925+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:01.574208925+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xFF, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x45, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0021 > > > >
2022-11-12T12:32:01.587754842+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:01.743425967+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.210377133+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.214709175+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -64, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x3A >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T12:32:02.225453175+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.340508050+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.344921800+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xD1, rssi: -64, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x46, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || ZclStatus: SUCCESS > > >
2022-11-12T12:32:02.355435550+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.540381884+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.545491925+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -64, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x47, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-11-12T12:32:02.556242550+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.588453300+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.594601300+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -64, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x48, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-11-12T12:32:02.603706925+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.607911842+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x02, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: OnOff >, lqi: 0xFF, rssi: -64, body_length: 0x0009, < ZDOMessageBody || < ZDOHeader || seqno: 0x03 >, GenericBody: FD FF 04 01 01 19 00 00 > >
2022-11-12T12:32:02.618314175+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.623959384+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:02.879681842+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:02.884432175+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0025, extended_status: 0x00, zone_id: 0x00, delay: 0x0001 > > >
2022-11-12T12:32:02.896969509+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-11-12T12:32:02.899879800+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-11-12T12:32:02.903545675+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“active”}}
2022-11-12T12:32:02.913552092+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:03.040002301+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:03.044162384+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -63, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x3B >, < BindRequestResponse || status: 0x00 > > >
2022-11-12T12:32:03.053548884+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:03.293512009+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:03.341306884+00:00 DEBUG Zigbee Motion Sensor Mc driver device thread event handled
2022-11-12T12:32:04.496022343+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:04.502256760+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -64, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T12:32:04.596162760+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:04.672366676+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:04.678029551+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -63, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T12:32:04.693659051+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:04.879681593+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:04.884299926+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -64, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-12T12:32:04.895262426+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
2022-11-12T12:32:06.879659594+00:00 TRACE Zigbee Motion Sensor Mc Received event with handler zigbee
2022-11-12T12:32:06.884552302+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x634D, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -63, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x01, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0024, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2022-11-12T12:32:06.896042177+00:00 TRACE Zigbee Motion Sensor Mc Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-11-12T12:32:06.899031802+00:00 INFO Zigbee Motion Sensor Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-11-12T12:32:06.902701844+00:00 INFO Zigbee Motion Sensor Mc <ZigbeeDevice: 6b194606-9620-484d-b544-7aa3e1105746 [0x634D] (Bosch Motion Sensor)> emitting event: {“attribute_id”:“motion”,“capability_id”:“motionSensor”,“component_id”:“main”,“state”:{“value”:“inactive”}}
2022-11-12T12:32:06.913141386+00:00 DEBUG Zigbee Motion Sensor Mc Bosch Motion Sensor device thread event handled
@robert.haugen
I had not modified the subdriver
Try pairing device with this version
 Version      2022-11-12T13:10:04.356591267
Now its Woking ok :ok_hand:
@robert.haugen & others: What steps did you follow to (re)add the motion sensor to the SmartThings Hub? I’ve used ‘scan nearby’ and tried to add the sensor from brands → Bosch → motion sensor, to no avail.
I’ve removed any custom legacy drivers, installed the new edge driver, and rebooted the hub. I’m using a v3 Hub.
Thanks in advance.
I had same issue. I had to remove the sensor and re-add them. They did not use anew edge driver when they were re-added but are using the legacy DTH.
Thanks @plgill99
Did the app allow you to add through the ‘scan nearby’ feature? I’ve removed mine as well, but it doesn’t show up when I try to re-add the sensor.
I removed and paired 6 of these devices. Remember, you must following the pairing instructions EXACTLY and don’t forget about the four second limitation.
I added them by Brand and then selected Bosch and then Radion PiR ZB Wireless Motion Detector.
hub v2 or v3? Would you mind sharing the pairing instructions?
ST v3 hub
Bosch Pro-Grade ZigBee Wireless Motion Detector ISW-ZPR1-WP13—
  1. Remove back cover.
  2. Remove top battery on each side.
  3. Make certain bottom batteries are pushed down into place.
  4. Wait 20 seconds at least.
  5. Line up top batteries into place but do not let positive touch.
  6. Put hub into pairing mode. Use Radion PIR ZB Wireless Motion Detector.
  7. Hold down tamper switch.
  8. Insert right battery and then left battery.
  9. Release tamper switch You only have 4 seconds from the time you input the right top battery until you release the tamper switch.
  10. After pairing, put back cover on.
  11. Change Sensor type in IDE to SmartSense Motion Sensor
Thanks. Do you use legacy device handler or edge driver?
For now, when I paired the Bosch motion sensors, I just used the legacy device handler.
I’m going to wait to tackle the new edge driver for the Bosch sensors in late December, once some of the other issues at smart things get resolved.
As an aside, every one of my devices went off-line. I had to manually pair every device and I have over 100 of them.
Thanks for the guidance. This is unfortunately not working for me - I’m following your instructions exactly. Pairing these sensors has always been tricky, but I’ve always managed. Right now, the app remains stuck on “Insert batteries into the sensor” and ultimately times out. I’m about ~2 feet from my hub as well. The red light on the sensor is blinking three times every 5-seconds or so.
p.s. sorry to hear you have to pair over a hundred… ouch!
That is exactly how my 5 sensors are behaving. they used to work fine before the last update and now I cannot even use the old IDE handlers because there is no option to re-add them. What hub are you using?
SmartThings v3
(I also deleted the legacy handlers btw)
I don’t think we can get these motion detectors to pair without the old device handlers… My hub went offline. That’s the reason I had to reset everything… I couldn’t get the hub back online without resetting everything… The only zigbee device I have gotten to pair is a Samsung button… All Z-Wave and Wi-Fi devices pair fine… Will try to pair two zigbee sirens later… Thanks everyone for the help…
