I have been using 12 Bosch Motion Sensors (ISW-ZPR1-WP13) with my EU v3 hub using Tomas Axerot 2017 device handler; this has worked well for the last 2 years.
In the last few weeks, all of these sensors have gone off line.
I have previously requested assistance in another thread that relates to these sensors with v2 hub. In that thread, one of the users with US v3 hub seems to have these working while there are many others with v3 hubs who are unable to.
The issue I am facing is that my hub is unable to discover these sensors, and therefore I am unable to pair them again. Many other Zigbee devices continue to work flawlessly.
In the other thread @andresg had said on 2 November that this is being investigated. But there has been no update since.
Can someone please look into this issue and please update?
Login to IDE and make sure the devices have been deleted. Users are reporting when they remove devices from the app, they are not being removed in IDE. Once you remove them in IDE, you should be able to pair them.
check the app or CLI to make sure they have not been converted to Edge drivers. I would not go by anything in IDE at this point. In the app, open the device, tap on the 3 dots in the upper right, if you see “Driver” listed in that menu then it has been migrated to Edge.
Same here. I have Hub version 3 and I cannot pair these Bosch sensors. The sensors keep blinking on pair mode and the Hub does not detect them. I have 6 of them and all have the same behavior.
Also having the same issue.
I am using a V3 hub in Australia and 2 out of 3 devices went offline. I removed the old IDE driver and tried to pair with no luck. I then added the Mariano Edge drivers I am still unable to pair. Strangely 1 of the 3 devices remains online with the old IDE driver.
To clarify
1 of the 3 devices is still online and running the Tomas Axerot DTH device handler
2 of 3 devices which were using the Tomas Axerot DTH device handler stopped working so I removed them then tried to pair after installing edge drivers.I am now unable to pair these devices to any driver.
tried excluding as well since you are unable to add them?
checked IDE to ensure they were fully removed?
you are using Add Device > Scan when attempting to pair? may take several attempts
not sure if the old device handler is the issue so you may want to consider removing the remaining one and the groovy device handler in IDE or you can wait for that one remaing device to be migrated
