Bloomsky Weather Station
Adding this to OP =D
David,
thanks
Tried that and am getting the following error with both my WU user name (same as ST) and Station name
I can see my weather station picture on WU if i search by zipcode (08534) and select my weather cam (brandon farms)
AccessDenied Access Denied D7D30189A27A67D5 VmpGsN4aMooOg1c1i6zsbOkmj8MIfUIlawU/JnFhVFzlPbn7yOUvPRFc7X3ARfJm9Liaaw/8588=
I was able to figure out my URL
the code is different for each user
if you look up your WU station online, and right click on the picture and select open in new window, it will show you the right URL for your BloomSky current image
http://icons.wunderground.com/webcamramdisk/b/a/“userName”/1/current.jpg
the two characters after webcamramdisk could be different for each camera (i have /b/a, David’s camera was /b/e/ )
BatraD, I would assume this is because your URL is an SSL connection.
Try going to http://www.wunderground.com/, sign-in and:
  1. Click on the person icon near the gear in the upper-right side of the page:
  2. And select My Weather Stations.
  3. Click on your weather Station Id:.
  4. Right-Click on the image and select Open image in new tab.
  5. Copy the URL from the new tab and change “https://” to “http://”.
  6. Paste this url into the SmartTiles Image URL field.
I hope that helps.
no SSL in my URL, i went without sign-in in to WU as a user, searched for my zip, found my WU station and right clicked on the picture to view in a new tab
@BatraD, try the sing-in method I provided and see if that helps. It may be that without sign-in your webdisk is not bein established by WU.
Sorry, I have no others ideas for you to try.
David,
i was able to view the image… just the link was different for me
/b/e needed to be replaced by
/b/a
thanks
Yes, each link for each user can be different, so everyone so be using the steps to generate the link.
Glad it worked out Devesh.
Looks like some more devices are shipping out, just got my shipping notice :slight_smile:
Anyone rain sensor still working with this device type? It was pouring today and the entire time my rain sensor says it’s dry in ST.
I hadn’t even noticed that it wasn’t reporting in ST, since I get the push notices from BS. You’re right, I just checked and even though it has been and still is pouring both of my BS are showing dry in ST. Although they are reading 97% and 98% humidity LOL
not mine…
I just reset my BS and the rain sensor started working again in ST. Must of been a glitch.
In ST or on the BS ? I am not climbing up on the roof in the rain to push the button LOL
Yeah, it’s called BS ST glitch…sorry was too funny not to say it :slight_smile: We need a better acronym for BloomSky, thouh then just BS…
On a serious note, I was very disappointed that I cannot use my PWS with my Iro. Anyone tried it to connect it to Rachio?
BM ? :poop: :poop: :poop:
Bloom Sky Glitch.
Poured here today also - just went through the device history and it shows wet and dry in ST at the appropriate times for me.
I can’t specifically speak about the Rachio (so this is probably stupid to say, but…), but my HydraWise WiFi smart sprinkler controller (arguably the best out there for the price-point) uses Weather Underground.
So, I was able to get my BloomSky’s weather data into my HydraWise via the BloomSky-to-WeatherUnderground route. I can also get it via the BloomSky-to-SmartThings-to-WeatherUnderground route (I have two Personal Weather Stations in my WU account in order to be better able to track down what’s going on in the event of a glitch).Rachio
Any chance the Rachio has WU connectivity as an option?
EDIT: Doh! I just realized that my last sentence was probably your question, and my post adds nothing…sorry.
Yeah, Rachio only takes PWS from
I contacted them today asking if I can add Bloomsky to their site and they said:
We haven’t been advised they have added the capability to send data to PWSweather.com to their devices. You might want to check with them and, if they haven’t, ask for them to do so.
@Yongfeng_Zhang any chance you might be able to work your magic?
