Alright everyone thanks for the responses. Iāve reached enough testers for now and if no major arrise I will open to more people.
Iām just making a few last minute modifications to the app and making sure I can put as much info into the readme as I can. I will send something out later today.
Thanks for your interest.
Iāve been trying to track down a bug causing issues which was hopefully just fixed. Once I get verification that it works and is working stable I will begin adding in more people.
Iām really intersted! i have a nest protect and 3 cams. Will be getting a thermostat soon too! Im really hoping for integration since other cameras arent that great that actually utilize zwave or zigbee
Just wanted to drop in and say thank you for your work @tonesto7 but not only that, this is an insanely professional looking SmartApp. If SmartThings/Nest can ever work things out to provide official integration, theyād do well to just use this.
I have a Nest Thermostat and at some point will get Protects around the house, I cannot wait for your official release.
When you say, āNo need to use Polling apps for device updatesā does that mean changes in temp, humid, and adjustments made to set temp are all pushed real time? I have some keen home vents that are itching for such a solution for the nest⦠Thanks!
The App handles all commands and polling removing the need for polling apps
Unfortunately the limitations ST has in place donāt allow real-time incoming events. The only way to make that work is with a self-hosted in between server to relay data to a Web Endpoint
