Aqara FP2 Tested with SmartThings?
This driver should fix the connection issues:
https://bestow-regional.api.smartthings.com/invite/d4299eAR0D2o
PR:
Your patience and tenacity are impressive, Andreas.
I enroll in the channel but it takes too long and it doesn’t work. can you help me?
@Mircea_Cosmin_Ionica That link doesn’t work anymore, it’s over 2 weeks old, and there have already been changes to the test driver since then anyway…
Having the same issue with the latest PR. Enrolling the hub it spins for over a minute then returns to saying enroll hub
Same for me
It doesn’t work for me. Whatever I do, the fp2 sensors are offline. Disappointing
You haven’t given much information; did you just swap from one driver to another in the app? “Not working” can mean many things—kind of like asking a German for directions and ending up with a 15-minute lecture on traffic laws. Here’s my procedure when testing a new driver: I have eight of these in deployment now, so you can imagine how intimate I am with this process.
Install the test FP2 driver onto the hub. Delete the official FP2 driver from the hub ( it will come back in 24 hours anyway). Screenshot your FP2 automations, delete the device from ST, delete (but not factory reset) the device from Aqara, re-include it to Aqara (your zones will return). Then, re-include it into ST, where it will join with the test driver. Lastly, redo your ST automations.
Hi,
I deleted the sensors from SmartThings. Press the reset of the sensor for 10 seconds. I include it in the aqara app and then in SmartThings. Where am I wrong? Thank you
After a hard reset and changing the plug adapter, the sensors stayed online. Thank you for your time and help.
Anyone had issues with their FP2 yesterday and today? Mine stopped reporting status yesterday morning. Shows online, but doesn’t report presence changes or luminance changes. Sensor is reporting presence changes and luminance changes in the Aqara app…
Tried unplugging/replugging, rebooting ST hub, rebooting wifi router multiple times to no avail.
What’s your firmware version?
There’s currently a firmware update being rolled out.
There’s an updated Aqara FP2 driver on the SmartThings beta channel if you want to try it.
 Aqara Presence Sensor   │ 2024-12-02T21:30:11.217562821
https://api.smartthings.com/invitation-web/accept?id=450930c1-02a6-43d8-adaa-4cbc51027956
Or just wait for the new official FP2 driver set to be released in 24-48 hours.
fp2: add get_credential failure handling
fp2: add nil check in eventsource
fp2: Label change for easy distinction
Offline event after reconnection attempt to prevent fake offline
fp2: remove socket connection for fp2 resource
fp2: update status when sse reconnect
FP2 FW is 1.2.8_0006.0086
ST FW is 54.14.
Device had worked without a hitch in ST since integration.
Right on cue, ST has released the latest official FP2 driver to our hubs.
Aqara Presence Sensor │ 2024-12-09T21:15:18.419597941
Curious to hear any reports about it’s function now…
It has been offline since despite multiple attempts at unplugging and replugging it back in and hub reboots.
This morning I reset it, re-added it to Aqara app (it retained my zone settings) and then was able to re-add to ST. I have to re-setup some rules I had in Sharptools for the “new” ST device and do some testing to make sure its all working properly again, but seems to be back online at least all day today.
Theres new Aqara FP2 firmware avalable now…
Released 04.12 depending on country.
It took half an hour for the device to return to normal. Didn’t recognize me, ghosts everywhere.
