I have both Wemo Smart LED light bulb and Osram Lightify, both A19 and work well with ST. The package clearly stated it will not operate with a dimmer switch.
Any ST compatible A19 smart bulb that can work with regular dimmer switch?
Thanks.
Thanks.
Why would you want to do this?
No smart bulb is ever compatible with a dimmer switch.
connected bulbs shouldn’t be used with dimmers.
Replace the switch with a normal on/off switch and use the dimming abilities of the bulb or use dimmable led with a dimming connected switch.
I moved to a new place when the dining room installed with the dimmer switch.
I guess replace it with a normal on/off switch is the only option.
