I can get my bulbs to connect to ST Hub and to Google Home but when I go into the ST app and try to adjust the color of the white it doesn’t give me the ability to do so. All I can change is the brightness? Anyone able to help?
I have a TW A19 on the ST system and it has the options to adjust the white.
Are you sure you got the model that allows color adjusting? The cheapest lightify bulb does not, only dimming.
Either you have the dimmable not the tunable white bulbs, or you are using the dimmable device type with the tunable bulbs.
How did you get it to connect? I bought one tonight and am having no luck at all.
You should be able to add it under things. If it’s not finding it. Flip your power switch on/of 5 times in 1 sec intervals to reset the Bulb. Then try adding to ST again.
That worked, thanks!
