Any advice on lost connections to devices
Ia few days ago I had 4 switches in my bedroom stop working and today. every switch in my bathroom stopped responding. I don’t even begin to know where to begin. It’s been perfect for 2 years. I repaired the network. Any advice would be appreciated
They are all different manufacturers, some are dimming some are non…
Have you rebooted your hub? Try reaching out to support to see what they can see in logs. I’m assuming hub v2?
You could have just 1 device failing and causing you all this grief. Check your Hub’s event logs for devices not responding and try Repairing one at a time until you find the problem device. The ide may also show the device as offline, so look for that.
