SmartThings Android 2.0.7 includes bug fixes and overall performance improvements for enhanced stability. In addition we worked on design polish, navigation flow improvements, copy changes. Notable feature improvements and bug fixes are detailed below.
Feature Improvements:
Updated the slider for lighting controls
Add text labels to menu icons at bottom of screen
Change reference of ‘Uninstall’ throughout the app to ‘Remove’
Removed “shop” link from context menu
Location Name in Header will now be listed as ‘My Home’ instead of the location name
Visual clean-up of sizing, spacing of lines, fonts, and icons
Confirmation message added when smartapps are successfully created/saved
Confirmation message added when new paired device is configured
BMW Apps and MINI Connected ready. Please install additionally the latest BMW or MINI Connected App from the Google Play Store
Bug Fixes:
Fixed, user can change a room image, but can’t unset it.
Fixed, Routine checkmark does not disappear after user executes Routine
Fixed, the Phone Number field for text notifications cannot be erased
Fixed, users cannot add or remove devices to rooms
Fixed, Smart Lights Crashes when configuring too quickly
Fixed, deleting device/smartapp used by routine causes an error to occur
Fixed, changing device name layers previous name over new name
Fixed, initial config screen in Device Getting Started Experience doesn’t display newly added room under “Select a Room”
Fixed, Activity Feed for SmartSense motion Temp is showing in the wrong format
Fixed, the temperature symbol doesn’t display properly with Ecobee
Fixed, in SmartApp preference, user cannot enter a negative number to a temperature field
Fixed, install a solution module that is incomplete bring users back to the dashboard and uninstalls it
tgauchat
#2
NB: This bug affected more than just Phone Number fields. I will test to confirm if the plain text fields SmartTiles uses for input of URL’s for Video Feeds and Off-Dashboard Links are also fixed.
EDIT: Seems fixed to me. I can’t reproduce the problem. Thanks!!!
Good:
-Text below icons at bottom, no more explaining to my wife and kids what they mean.
-Much faster, hasn’t crashed yet.
-Like the horizontal slider in multiTile for lighting, much easier to use.
Bad:
-MultiTile type “thermostat” is now just a “?” where before it “worked” without any extended functionality. This is a huge step backwards.
-Getting “There may be problems with your network” errors loading things view or marketplace
-Samsung SmartCam UI now has a gray box where the play icon was after pressing it. It disappears after a few seconds. (Might be a “stop” icon? but just looks like a gray square.)
-Main section titles were change to Italics? Renders pretty bad on my screen and hard to read.
-Buttons at bottom with new text are very fuzzy, look low res on my hiDPI screen.
can’t speak to the functionality and bugs that others are pointing out but I will say for a newbie still learning the labeling/formatting/etc make it easier for me to find my way around since things still aren’t second nature to me just yet.
I don’t have a mode “Home” so I don’t see what you see. The “Broken Spyglass” is a reference to the broken gradient circle on the image that just seems to take up so much valuable space. Thus I consider it broken.
Maybe this is tied to routines and not just modes.
gotcha- it is a big wasted space- i kavetched in an earlier thread myself- lol. It should do that thing (in android at least) where it scrolls off the page when you scroll down but as soon as you scroll back up it comes back.
Says a lot of fixes, but why can’t we get reordering within rooms fixed, missed two updates in a row?
I still hate the fact that most sensor type devices still have no colored-graphical status, much easier if the same status graphics from the tiles are shown on the room and things pages, this was all good in version 1.
