RBoy
1
Interestingly ST moderators closed the Android 2.0.7 release thread so I’m starting one here to tag bugs I’ve found.
2.0.6 is infinitely better than 2.0.7, this is a regression release.
Things broken so far:
.1. multiAttributeTiles for type thermostat cause a ? in the display (regression bug, worked fine in 2.0.6)
.2. hidden and hideable section attributes do not work
Here’s a two new ones I found today:
.3. Using the “range” attribute in a input causes the ST app to crash for decimal inputs
–dynamic page submitOnChange is not honored for numeric and text inputs (possibly others as well), enum and device selections work as expected (this has never worked to my knowledge)
–inputs of device.deviceTypeName produce an empty selection set, this worked prior to 2.0.5 If I remember.
–Range appears to work correctly for integers
I can’t even begin to list the errors because I am not sure what they are. All I know is that this release is the absolute worst since I obtained ST 15 months ago. It seems every page I get the dreaded “An unexpected error occurred…” or some error. I am at the point now where this version is almost unusable.
I am still on 2.0.6 and for the past few days have seen the Unexpected Error popping up. When I was running on 2.0.7 the errors seemed more prevalent. When 2.0.7 first came out there were a lot off these errors and that is why i went back to 2.0.6 but still had the errors, just not as much. Then a week later everything cleared up. Now the past 5 days they are popping back up again. Whatever it causing it, it is not directly caused by the latest version.
