All Schlage lock Offline at same time
So all my schlage locks went offline at the same time. Has anyone else having this issue?
Nope, my are fine
Are you using a different DH?
Yes, one from @RBoy. It never fails
So after some detective work I found that each of my locks had a device offline between it and the hub causing my issues. Very weird…
You may want to do a Z-Wave repair. Usually if one device in the chain is offline it should automatically pick a different route. A Z-Wave repair can help fix those routing issues.
This is the device handler @milandjurovic71 is referring to (which can access advanced features for Schlage locks and also fixed a few bugs in the locks firmware which can cause loss of information while communicating with the hub).
