Alexa not seeing Smartthings hub after Skill update December 2019
Hi.
The Alexa android app had a ST Skill update.
Now I can not see the ST hub.
I have reset alexa(dot) still the same.
When I signed in to the skill with my Samsung account. I picked the one with 13 things.
Asked Alexa to discover new devices and nothing!
Everything was working fine
What can I do next?
Thanks in advance.
OK so I used a new echo dot and most of the devices showed up.
But not my Z-Wave Window Shade device.
I can see it on my IDE and Smartthings can control it. But for some reason Alexa won’t\can’t see this device.
thoughts?
Something weird about the most recent Alexa app update. :thinking:
I had to reboot my echo devices (unplug for 10 seconds, plug back in.) before they could find all of my smart home stuff. Whether it was smartthings or not.
I gone back android alexa versions but still the same.
Still can’t see my Z-Wave Window Shade device which is a zemismart curtain rail.
Looks like looking for a new z-wave and zigbee hub.
I’ve done a factory reset of alexa and deleted every device at alexa.amzon.co.uk.
I add the smartthings skill and it adds all of the ST hub devices except the z-Wave one>
Anyone know if have to do some thing in my IDE?
Did that device used to work with Alexa for you?
I only set it up this week.
But yes Alexa did see it via Smartthings hub.
But now it doesn’t. I did another complete reset of Alexa.
The first I did was to add the ST hub skill( which was updated a few days ago)
I picked my home with 13 devices. But Alexa only imports 12.
I have been on my IDE to see if I can change something. But no luck.
I made a scene in ST to close the curtain.
But alexa says the device does not support it?
Anything else I can try?
EDIT
The scenes work but you have to say Alexa-Start (name of scene)
Not very good. But it’s the best I can come up with.
Just in case someone is following this.
I went to my IDE and chose the curtain and then chose edit.
Under device name I changed it to switch.
Alexa does work but you have to say “Curtain on” or “curtain off” I am still messing :slight_smile:
The SmartThings skill doesn’t currently support curtain capabilities. There was something weird with the last skill update. I had to disable and re-enable it to get new devices in ST discovered.
