Aeotec Smart Home Hub/2018/2015 Model Hub Firmware Release Notes - 0.43.4
We will begin rolling out Samsung SmartThings Hub firmware version 0.43.4 starting Monday, June 06. Once downloaded, your Hub will briefly go offline as it reboots and applies the update; most customers will experience less than one minute of downtime. We will update the status page when the release is complete.
Hub Target:
  • Samsung SmartThings Hub 2015 (Hub v2)
  • Samsung SmartThings Hub 2018 (Hub v3)
  • Aeotec Smart Home Hub
Release Date: 06 June 2022~ 10 June 2022
Note that this release may be spread out over a week, so you may not see your Hub update the first day of the release period.
Release Notes
Edge Drivers
  • A number of bugs in the use of both UDP and TCP sockets were fixed
    • These fixes make it a requirement that all socket methods must account for the potential return value nil, "timeout"
  • Fixed a bug in cosock.asyncify that was incorrectly resolving require "socket" when using ssl.https or urls with an https scheme
  • Fix bug when re-using a table value for capability event generation
  • Fix timer cancellation in the test framework
  • Correctly handle Zigbee message equality test in test framework regardless of message construction method
  • Add type checking on timer creation to provide better error messages when failing due to non-numeric timeouts
  • Add ids to profiles for test devices
  • Allow tests to expect a raised error
  • Fixed a bug in cosock.asyncify that was not recursively swapping out calls to require("socket")
  • Fixed a bug in ssl.https that was referencing a non-existent property
  • Fixed a bug in cosock.tcp where receives would incorrectly insert the prefix argument across timeouts
  • Updated the API version from 0 to 1
    • This property can be accessed via require("version").api
LAN Driver Developer Action Required!
Developers of LAN drivers will likely need to make changes to their drivers to handle updates made to fix bugs in this release. First, let’s cover what changes need to be made to allow for HTTP requests to work after this update. A driver may have something like the following example for an event handler or an interval timer callback.
TLDR
local http = require "socket.http"
local json = require "st.json"
function get_device_state(device_url)
  local body, status_code, headers, status_msg = http.request(device_url)
  if not body then
    return nil, status_code --error message here
  if status_code == 200 then
    return json.decode(body)
  else
    return nil, string.format("Error requesting state: %s", status_msg)
  end
end
On line 5 (local body, status_code....) we will always and immediately get the return value nil, “timeout” which we can solve by changing line 1(local http = require) to the following:
local cosock = require "cosock"
local http = cosock.asyncify "socket.http"
In this release, we made changes to our native socket implementation to make it more closely aligned with our driver framework. It has always been the case that any use of the native socket APIs inside of our driver framework will eventually result in confusing and very difficult to debug errors. That first example may have worked as expected on our platform, but eventually, we would see some error message or the driver lock up entirely without any explanation. The reason these things would happen has to do with how Lua’s co-routines work when we call functions that block the main thread from a co-routine. By moving the code to use the co-routine aware equivalent we can avoid this whole class of bugs entirely.
If it can help, I point out that the email received does not have the correct link to this topic. (the link is empty)
I wasn’t even aware that my beta hub had been upgraded from 0.43.3 to 0.43.4. I suppose that isn’t a bad sign in itself but it makes for a rather passive beta test.
I found out it updated when my “turn off after 6 hours” automations didn’t turn off.
Switched those to a fixed time to turn off.
Still no update for the SmartThings Wifi Hub (mesh network) :frowning: :frowning: :frowning: :frowning:
COME ON!!! GUYS!!! Staff team!!! DO SOMETHING!!! no firmware update since long time ago and hub still not support EDGE Drivers…
Come on guys what’s did you do???
As nayelyz says many time…
Please check my comment in this post:
Our team is aware of some behavior that is preventing some Edge functionality on the Samsung Connect Home and SmartThings WiFi devices from working as intended. We are working on correcting this behavior and hope to have it resolved in a future firmware release for these devices.
Hi! I’ve been talking to the team and they mentioned there will be an announcement about this release, they’re just checking the actual date for it.
We don’t want to provide inaccurate information, that’s why there is no concrete news about it.
Note: I don’t know if the development is completed, that’s all the information I have.
These are great! Thanks for getting those patched so quickly. Looking forward to removing the duct tape from my drivers and testing this out. :+1:
Thanks nayelyz I know it’s not your fault!
The fault is on the engineering, developer team!! The message is for those guys, those teams! not you nayelyz… >> Team of engineers and developers you provide many updates for other hub regularly many times a year and SmartThings Wifi user is on the side for so long!! It’s like no consideration for WiFi user it’s decent Hub working great and supposed to follow update road map as the same as other…
Very disappointed more and more each time I see you release new update for other hub model then again you send us like slap in the face, said to us you know WIFI user you are not important for us!!! :frowning: :frowning: :frowning:
