Aeotec Siren 6 Not Updating Status: Work Around
Posting this in hopes that it helps someone else when they’re having problems getting an Aeotec 6 Siren installed and fully functional.
I installed an Aeotec Siren 6, but had to remove/uninstall it for testing. I removed it properly from the Z-Wave Network, then installed it again.
However, upon reinstallation, Sound/End Points 2-8 were disabled and I would receive the pop-up message every time I opened the Device Card: “This device hasn’t updated all of its status information yet. Check again later.
As well, in the API Browser+, all of the Sounds had a value of “null”:
No matter how many times I refreshed the card, it would not update its status. I tried resetting the Siren to Factory defaults, a Z-Wave Repair, Removing/Reinstalling it multiple times, different drivers. Nothing worked!
I noticed upon testing an Alarm Routine (which activated Sound/End Point 3), that Sound/End Point 3 was now enabled.
So here’s the Work-Around to enable all of the Sound/End Points and get rid of the “device hasn’t updated” message: I ran a routine to activate all of the Sounds/Chimes 1-8 (one at a time).
Note: I am using the SmartThings Managed Edge Drivers, Z-Wave Siren
The API Browser+ Now Indicates “off”, instead of “null”:
Thank you so much! This worked for me, not sure what I would do without folks like you!!
Glad it helped!
Another question please and I have looked but can’t find anything on it. Is there a way to control the duration of the sound? right now it sounds for a few seconds or so then turns off. How do you control or make it go longer? For example, I have a water leak, I want it to chime/sound until I turn it off.
Thanks in advance,
Alan
Are you using SmartThings HomeMonitor to alert you as to the leaks?
If so, check out:
  1. Home Monitor >
  2. Gear (setup)
  3. Leaks
  4. Set Response
  5. Alert Duration
What is the Alert Duration currently set to (mine is 3 minutes) ? You could try extending that.
